Home | Pro-Fit | Pro.Fit Dg 71 01 Dodge Dakota Pic... | Headlight adjustment
Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota Pickup/Durango 01 Up
Problem for Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota Pickup/Durango 01 Up
By shrek54 on Sep 07, 2009
dakota 2001 how do you adjust the head lights
Best Solution
posted on Nov 04, 2009
Very Helpful)
super_guy
Rank: Guru
Rating: 97%, 7868 votes
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
posted on Sep 08, 2009
Not Rated)
trailmaker4
Rank: Master
Rating: 83%, 8 votes
when you pop the hood, at the back of your headlights, you are going to see two knobs which can be turned clockwise or counterclockwise by either your hand or a short screwdriver. one knob is for the vertical direction and the other one is for the horizontal one
Was this helpful?
Yes
No
Popular Solutions for Pro-Fit Pro.Fit Dg 71 01 Dodge
Questions and Unsolved Problems for Pro-Fit Pro.Fit Dg 71 01 Dodge
Do you recommend Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota Pickup/Durango 01 Up?
Answer
Answer
2001 dodge dakota 3.9l engine code p0320 ,says ing/dist circuit malfunction. engine does not fire.it... (More)
Answer
Describe your how set timing 1989 dodge Dakota Problem what wires do i pull or vaccum line to set... (More)
Answer
2004 durango back air wont get cold.. the front works fine.. my kids are burning up in the back.... (More)
Answer
Donde esta ubicado el sensor que enciende Low Coolant en una Dakota 99 diesel?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pro-Fit Pro.Fit Dg 71 01 Dodge...:
Top Car Audio and Vid... Experts
Rank: Guru Guru
Solutions: 14780
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Audio and Vid... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
