I got my Intel Motherboard replaced 5 days back and now if i start my PC it shows a Blue screen Error. Can any one suggest me what the issue is actually! Thanks in advance Regards Ganesh S
  • 1 more comment
  • Ganesh S Sep 07, 2009
    But my motherboard's same as i replaced. Intel got me a new motherboard. Will the things become Ok if i reinstall my OS?
    I have done these steps of troubleshooting. Still the problem persists.
  • Mitesh Kr Anand May 11, 2010
    Did you reinstall the Operating System again? This issue may occurs if you are still using the previous installed Operating System.
  • 205 Answers
Check your motherboard's specification regarding to RAM and try to boot your computer with a new RAM. May be it can help you.
Posted on Sep 07, 2009
    President:
  • 1,187 Answers
Yup! Start the computer and get into the BIOS (press the "del"ete key after you turn on the PC.
One of the last menus is "reset settings to default" (or words to that effect).
Save the changes (F10?) .. Widows will boot and after it "settles", it will "find" new hardware.... Allow it to proceed.
I'm sure other (new) issues will appear. Come back and post those issues for a resolution.
Hope this helps!
  • 227 Answers
Did you replace it with the exact same board?? There is a piece of hardware conflicting somewhere within the system. Usually when you replace hardware you have to configure windows to run with it. You can fix this by running the repair option with windows os disk. If the motherboard is not the same as what you had it will cause windows to blue screen of death. The only way to fix it is to reinstall or repair windows.
  • Michael Beverlin Sep 08, 2009
    Things should be just fine if you reinstall windows. Even if it is tha exact same board, there might be something different with the board even if its just alike. Maybe a transitor or something. There are many aspects of the hardware that windows uses to run. If just a slight change in those specs and windows will go crazy. Like I posted in the beginning, if you have windows disk, you can repair windows. It acts like its installing a new windows, but in reality its just making changes to itself to accomidate the new specs.
    Windows, after it runs its set up, will hask you if you want to repair windows or install a new copy. Hit repair and it will make all the needed changes without loosing all you saved data.
I have a MS-7101 motherboard with a Pentium 4 Dual Core CPU based system . RAM is 512 MB (DDR) . However , sometime after I have switched on the P.C. , the screen (display) suddenly starts going bad ....
Most of the distorted display related to video memory. MS-7101 Motherboard coming with embedded video controller so your system memory is sharing space for the video memory. Replace and check your system RAM or check RAM module with Memtest , if it is showing error u should replace memory module.
May 10, 2011 | Intel Motherboard
Have sent it in for hard drive problems with BIOS and blue screen. HP update BIOS and sent back still same problem so sent back and they replaced hard drive. Now same problem and technician said mother...
1. A "blue-screen" can be caused either by faulty hardware (such as a bad stick of RAM) or by a screw-up within the installed copy of Microsoft Windows.
2. Updating the BIOS will not "cure" any hardware problem, but it may "tune-up" the motherboard's interaction with some other component, e.g., a network-card or a video-card.
3. Updating the BIOS will not prevent any "screw-up" within Windows.
4. Replacing the motherboard, while keeping the same RAM, will not cure any "bad RAM" problems.
5. Replacing the keyboard or mouse or speakers will not "cure" the problem.
6. If they inspected the motherboard, and they found liquid damage (spill of some soft-drink or beer or cream/sugar coffee) that is causing short-circuits on the motherboard, then it depends whether you purchased an "all-perils" warranty that covers user-induced damage (dropped computer, liquid spills) or whether you have a "standard" warranty (to replace a disk-drive that dies).
7. If they replaced the hard-drive, then they (or you) probably installed a "fresh" copy of Windows, which tends to rule-out any "software" problems that would cause a blue-screen.
My suggestion: borrow a Windows 7 DVD from a friend, and boot from it. One of the start-up options is to run a "RAM-test", to extensively test the RAM for faults.
4.
Aug 19, 2010 | HP Pavilion dv5t- Intel(R) Core(TM)2 Duo...
Asus CM5570 Powers on 20sec/off 5sec/on to stay, no video or POST
i think that there is a problem with SMPS ( power supply) try barrow the SMPS from any one for few hrs. it will resolve the issue.
May 13, 2010 | ASUS Essentio Desktop with Intel Core 2...
Blue screen error top:c0000221
faheemrhafle
To better help me address what is causing your Blue Screen of Death I need to know the error message that it lists too. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Apr 19, 2010 | Intel Motherboard
Gx270 dell During istall of OEM XP I get blue screen codes 24,8,&
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 41f927c.jpgd3990ed.jpgALL these systems suffered from defective capacitors caused by bad manufacturing at the component factory. I have put here a pic or two for you to see what defective caps look like. Call Dell and ask them. I some case a while back they were doing a free motherboard replacement. The problem causes a whole raft of errors to occur from blue screens to "thermal event error" and the only thing that fixes it is to have the motherboard replaced. Hope this helps you
Kind regards from London
Mark
Aug 25, 2009 | Dell Optiplex GX270 Intel Refurbished...
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
Computer hang in intel screen
hi remove your motherboard and..service 1st and .. check .. your ram.. there is something wrong ..
thnx .
May 14, 2009 | Intel Motherboard
Blue screen error occured when start os installation after create partition,
The blue screen during reformatting is not an issue with the motherboard. The issue is with the hard drive. Find or purchase a new hard drive and try to reinstall Windows on the new drive.
May 09, 2009 | Intel D101GGC Motherboard
Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
Kees,
It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
