Question about Car Audio & Video
Hi. I have a X704 amp and it seems to have a power protector on it. It holds a green light on and flashes off. After a while it holds a green light on and the flahes red quickly and back to green. Is there a reset on this amp or anything you have come across which may cause this problem. Cheers Matt
  • 733 Answers
Check all your wires to make sure there is no short. a shorted audio wire will cause it to go into self protect mode.
Posted on Sep 07, 2009
Internal fuse
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Apr 02, 2014 | Hifonics Car Audio & Video
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
Power light keeps flashing
Normally power light on router is stable solid Green! If you notice the power light is flashing its better to use surge protector! Also try to power off once and wait for a minute or two and power on again. Its always better to use electricity surge protector for all computer equipment!
Oct 02, 2011 | Linksys Wireless-G WRT54G Router
TV turns itself off and power light flashes green
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
Jan 27, 2008 | Computers & Internet
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
