Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
I rfeset timer to turn on earlier - now the lights won't turn on
When I try to turn them on manuall - I get a no op see instr response
    President:
  • 704 Answers
Randi, first thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers fail, as certain models have a known history of failing fairly often.
NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
Whole house fan
no-op means no operation.
Replace battery, and reset timer... if functionality is not restored, then replace timer
http://waterheatertimer.org/ST01C-program.html#battery
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Gene
Apr 06, 2014 | Intermatic Hardware & Accessories
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
I tried the auto code search for my sentry rmc 10 and the device turned off but won't turn back on I have an older vizio
you must reset the code again use the code from your instr. manual. and proof again.
Retight the spring contacts battery with pliers for a good contacts
2) clean the contacts battery.
3) resolder the wires contacts battery
God bless you
Aug 02, 2012 | Televison & Video
I connected out door X mas lights to the Utilitech 3 outlet photocell timer. the lights went on at dusk, as they were supposed to. But they started blinking on and off. what is worng?
Unfortunately someone went to great lengths to copy/paste the wrong instruction guide to this solution. Like me, the OP has a 3 outlet PHOTOCELL timer, not a 2 outlet DIGITAL timer. Photocell determines dusk/daylight/etc. We also have the same issue. Wondering if has to be connected directly to outlet. Ours worked fine when plugged into outlet. When we moved it after Xmas to run year-round lights, plugged into extension cord and problems began. No response to date on emails sent to mfg.
Nov 12, 2011 | Hardware & Accessories
Need instr. manual for Orbit gardfen timer stage 4 or stage 6
I cannot identify that specific timer.
Open following link for Orbit manuals: There is a photo for each timer for easy identification.
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Sep 27, 2011 | GARDENA Water Timer #31169-4
No op on window and does not turn lights on or off
1) I read somewhere that folks have fixed the 'no op' problem by removing screws on back of timer and adding bit of oil to the gear.
I don't know if this works, or if repair lasts.
When that information was posted, several people said it was a good solution.
2) Otherwise you might try changing the battery.
3) Reset timer:
ST01C timer: Hold down ON-OFF and push in reset button.
Keep holding down ON-OFF until INIT shows, and then release and 12:00 should display.
EJ500 timer: Same instructions except hold down Next/ON/OFF
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Intermatic Hardware & Accessories
Please i need help i dont know how to set my timer and it wont st
See response to Turn off Beeps, its the same. Just click on the Mid Size Sports 1440 Black Nylon Strap Watch link and look for Turn Off Beeps solution.
Dec 29, 2008 | Timex 1440 Nylon watch
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
358 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
