Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Mixer quit working
Several months ago my friend was making bread with my KitchenAid mixer. She says the machine just stopped. She let it stand for several minutes and it still did not work. So she thought it was not working at all. But yesterday I tried it so see what happened and it worked. I ran it for 10 minutes and it seemed to work OK, but was noisy. Although I was running it with no load on it. I just had the beater attached to it. I don’t really know what would happen if I put a load on it. What do you think is wrong with it, and how could I fix it?
  • 45 Answers
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Posted on Sep 07, 2009
Testimonial: "Thanks for the input. I'll try that. I'm hoping it isn't something real major. "
I have an Epicurean mixer 475 watt, Model @ KT2651XWW use, used 2 mo. ago. Cake mix, now I am needing to use it and it will not turn on at all, went thru all gear (nixer) speeds, nothing. Help!
Posted on Sep 08, 2009
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Kp26m1xwh Kitchenaid mixer 575 watt stopped working.
On the back of the mixer is a screw holding on the Kitchenaid name plate band that wraps around the mixer. Remove this screw and the name plate and then you'll see four screws (two on each side) holding on the top cover for the mixer. Remove the four screws and then lift off the top cover and you'll see the motor, circuit board and gear box that operate the mixer.
May 29, 2010 | KitchenAid KP26M1X Stand Mixer
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY KITCHENAID KSM90 MIXER. I HAVE NEVER MADE BREAD IN MY MIXER, I DO NOT HAVE A MANUAL.
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Mar 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
KSM90 Kitchen Gets stuck in the middle of mixing Bread Dough
Hi
If you decide to get rid of it can you sell the accessories parts?. I have one with no parts.
Thanks,
Barak
baraksch@nana.co.il
Nov 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
HELP!!
The instructions advise to not run above speed 2 with the dough hook, making bread. This might be what caused it to be destroyed.
Mar 22, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
686 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
