Question about KitchenAid Architect® KEMS308SSS Stainless Steel Oven
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now nothing will work.
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Posted on Oct 27, 2012
Hold down "0" for a few seconds.
Hope this helps
Posted on Sep 25, 2009
    Sergeant:
    Champion:
  • 205 Answers
Mam please check the heat temperature limit of the sensor and if its less than 300 degrees please change it then it will works.
Posted on Sep 07, 2009
The probe light is on as well as the question remove probe or enter probe temp. This will not go away. We never used this option. We turned breaker off for 10minutes or longer... Pushed some buttons .
Make sure there is not food residue on the probe jack, it will ground the jack and make the control "think" the probe is in use. You can also send the control in to be refurbished... the solder joints on all of these machines are failing badly by now...
Oct 09, 2014 | KitchenAid Kitchen Aid KEBS277SBL Double...
Temperature probe icon persists on the display and cannot be extinguished. Seems to be locking out other oven functions. Tried removing power overnight - no change. Followed protocol to turn off "Sabbath...
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
Jan 10, 2010 | KitchenAid KEBC107 Electric Single Oven
Our Superba (what a joke) Model KEMS308 / KEMS378 has the exact same temperature probe problem where the plug where the probe is inserted is supposedly getting dirty BECAUSE THERE ISN'T A COVER OVER IT...
Common Problem, design defect allows moisture or corrosion on terminals, to cause this problem. Two ways of repairing this. 1: Plug probe in, hang probe out the door, input 160 degree probe temp, turn convection bake to 450 degrees and let it bake for a while. Turn unit off, unplug probe and test to see if the problem is resolved. If it is moisture, the high heat bakes out the moisture and resolves the issue. We have also had some luck with a hair dryer blowing on the probe receptacle to dry out the receptacle. 2: You can pull the entire unit out of the wal with the power off at the circuit breaker, remove the backing panel, and disconnect the wiring to the probe. Some units you have to remove a side panel instead. You won't be able to use the probe in the future if you do this, and you do have to insulate the wires terminals or plug. As always, if you don't know what you are doing with electricity, call a technician to do this repair, it is better to be safe. Also as an aside, I work on all brands of ovens and we find that the Kitchen Aid models have the fewest repairs and the greatest reliability, everybody has design defects and most of the other brands have deliberately built in these defects for faster replacement. The only advice on the Kitchen Aid units that I recommend is that when you do replace it that you buy a separate oven and seperate microwave oven. Most microwave ovens are only lasting 8 to 15 years before major repairs, yet the ovens last 30 to 40 years. Good Luck, Appliance Specialists
Jan 03, 2010 | KitchenAid Architect® KEMS378S Electric...
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
New oven won't work
cobrapilot sorry to be the bearer of bad news. Some where in the oven the contacts going to the oven probe are closing. This could be wiring going to the probe missing insulation and hitting the sheet metal, or the probe socket itself closed. I usually see this after the unit is in use, not right after install. Have you tried to cook a roast or such in the probe mode to see if it will work? For the oven may work just fine then. You are correct about your last line, until service resolves this issue, you have just an expensive microwave. Also as a side note, be sure an be there when the tech showes up. They may just try to say we need a part and not actually attempt to fix your unit. I am not sure what area you are in, however try Olson Appliance Service, He has a website, he is authorized Kitchen Aide service and maybe he can help.
Feb 03, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect® KEMS308SSS Stainless Steel Oven Logo
944 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
