Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
EOS DIGITAL solution disk
I just got my camera and tried to load the solution disk on my computer. i got a message that says screen resolution to execute the EOS disk is not sufficient. since i have a brand new high resolution lcd monitor, i am confused by this message. any idea what's wrong?
    Novelist:
  • 148 Answers
Clear you computer desktop of misc files. then right click on a blank spot on the desktop. select 'properties' then select 'settings' where you will find the video resolution screen. adjust to a higher resolution in one increment. apply, and if it does not look good to you then revert and take another setting up from that one.
this is an easy function to fool with. there will likely be several choices and they often change the correctness of the image as it fits on your particular display aspect ratio (width vs. hight) and the result will be a not very pleasing image due to shrinking or stretching. also, you may find a setting that your monitor does not like for one reason or another. it could cause your image to become unreadable. do nothing if it looks bad or you can't see it clearly, as it will always revert to original settings on its own unless you tell it you like it. so be sure to hesitate if you are not sure. if you select a setting that your monitor or driver can not handle, you might have an unreadable screen, which makes changing it back very hard.
good luck
mark.
Posted on Dec 24, 2007
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
Unable to download EOS Solution Disk due to computers low screen resolution'
You don't have to use Canon software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 30, 2010 | Canon Rebel XT / EOS 350D Digital Camera
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Dec 30, 2008 | Canon Cameras
Hi, I just bought a Canon Rebel, and I'm trying to download the EOS Digital Solution DIsck and I'm getting a message that says my screen resoltution is not sufficient? Help.
This is an easy fix.
Go to your control panel. Click start/control panel/display/settings.
There you will find your screen resolution slider. Slide all the way up to high resolution and apply settings. Your icons and everything on your screen will be smaller.
Install disk and go back and set your resolution as low or high as you wish once installed!
Hope this helps!
May 29, 2008 | Canon Cameras
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
224 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
