Question about Vizio VX37L Television
Vizio 47" 1080 LCD Auto Scan Freeze
90% of the time it will scan through the Anaalog channels and freeze about 3/4 through digital cahnnels. Usually freezes after 7 digital channels, but sometimes 30. On rare occasion it completes the scan.
SOURCE: Digital channels freeze
I also had this channel 5-1 freezing problem and spoke with Vizio support a few times. They thought the problem was the SSID code from the local CBS station and said they would try talking with them. I am not certain if they did this or not, but, as of mid December, my Vizio no longer has this problem.
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: No digital signal search
Check your manual to see if it has 2 tuners, digital and analog. If it doesn't have a digital tuner, you will need a converter box.
Posted on Jun 02, 2009
Shuttle83
  • 1139 Answers
SOURCE: Digital TV freezes now that the digital conversion is done
Do you remember in the old days when you got bad reception and the TV would get snowy? That was due to the signal strength of the incoming signal was not strong enough. We with digital TV you can still have a situation where the signal is weak, since you are looking at a digital picture the video and audio are packetize, and being packets they are first fed into a buffer and then sent to the decoding section of your TV. Now think about this when the signal becomes weak and the data stream is corrupted to the point that the processor rejects the stream that data which is in the buffer plays out and the last thing in the buffer is what you see on the screen (frozen image on the screen) until the signal strength goes back to normal and the buffer fills up again.
How do you stop this, well that's a hard question since the buffer underflow is the result of signal degradation, the cure would be to prevent the signal from degrading. This can be done with the use of an HDTV antenna (too expensive), an amplified antenna (priced ok for some but still too pricy for most), a rabbit ear type antenna with an amplifier added (this will work for most people), or just a plain set of rabbit ears (dipole antenna). All of these are options that can help you.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 17, 2009
SOURCE: Trying to scan channels into my vizio, but no
I called my satellite provider. Problem solved!
Posted on Jul 07, 2009
SOURCE: when my tv is on for about 15 mins the borders
something is wrong call vizio i bought the same tv two days later all of the color on the screen that should be black is green called repairman who came tv was working and after he replaced the mother board and daughter board tv was black turned on but no pic he tried again and i heard the arching sound he zapped it i was told by repair we need to order the power board it willl be another 3 to 5 days
i called vizio the minute that he left i was so pissed and that is not like me they are sending a new tv that was thursday i still have to wait 7 to 10 days but they are standing behind there tv i will give them that
Posted on Aug 04, 2009
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Aug 22, 2012 | Televison & Video
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
I have misplaced the users manual.
1) Connect the Signal Source - ANTENNA or CABLE.
2) Go into the menu for channel source and select the input you are using.
3) Go into the menu and SCAN/auto program all the channels.
You can now select your station.
Feb 23, 2009 | Vizio L32 32 in. LCD HDTV
May 06, 2008 | Vizio GV42L 42 in. LCD Television
LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Aug 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vizio VX37L Television Logo
496 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
