Vertical lines in the monitor NEC 1890 SXi
Vertical lines in the left side of the monitor if it is working continously for one hour.
If we switch off, wait for cooling, switch ON lines dissappear.
    Master:
    Sergeant:
  • 460 Answers
It is a hardware problem.so pls repaired it from computer shop.
Posted on Sep 07, 2009
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
Vertical BlueGreen band
check for vertical ic and replace
May 25, 2009 | Computers & Internet
Screen goes to single horizontal line across middle, sometimes momentarily at first, then resets after being switched off for a period of time (can take minutes, hours or even days) Model: NEC Mitsubishi...
  • Complete service manual with an error search tree , sometimes there is a vertical ic defect by deformed capacitors hanging around that or a powerline from powersupply failed (sometimes there could be a defect fuse resistor to find ) or only a bad factory cold soldering by manipulate some passive components somewhere in vertical stage .
Mitsubishi Diamond Plus 93SB Service Manual
May 06, 2017 | NEC Mitsubishi Diamond Plus 93SB 19" CRT...
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
