Question about Western Digital Caviar SE WD800JD SATA Hard Drive
Proper or Best way to use my newly installed WD SATA external Hard Drive;
My original and existing hard drive on my computer is only 40GB, actual space some 33GB. Because it filled up I purchased an WD(Western Digital) SATA Hard Drive with 350 GB, actual total size 232GB. Had it set up for use by an IT or computer store. It works, as I have already 5GB of data on it.
My question is:
What is the best way to use this external hard drive so that my computer HD does not fill up again? it is now down again to some 700.57 MB.
Do I just turn the external HD on every time I use the computer? will the data & stuff automatically load unto the external HD and not onto the computer?
Do I have to download from my computer hard drive onto the external one any data to make space?
I am at a loss as to how best to use the external HD. When I bought it, I thought the data will automatically load onto the external HD. Instead I continued to receive notification that "MY Hard Drive" is running out of space.
Please help with some suggestions. I would appreciate it.
I am using an IBM Think Center Desktop, Type:8085-33U, A50, XP/Pro, Service Pack 3, 1GB Ram, 33.35GB original HD space, Current free space: 700.57 MB
I have another external drive for back-ups only and I have backed up onto it a few times, not that I know how to retrieve the data yet in case of computer failure.
Again, Your help would be very much appreciated,
Thank you,
Heinrich Della Scala
E-mail: scala@istar.ca or heinrich.hds@gmail.com,
Best use the gmail in case your's gets put into the spam or Junk Mail box.
  • Heinrich Dec 09, 2007
    Thank you for your suggestions. I will try to follow them and if I have any further questions I will write.
    Thanks again,
    Heinrich
    Thank you for the help. I will follow your instructions and hope the desired effect will take place.
    Thank you,
    Heinrich
    Brigadier General:
  • 6,966 Answers
Based on your post/description and your queries:
1. What is the best way to use this external hard drive so that my computer HD does not fill up again?
I would suggest that you move most if not all of your work files (not system files) to the WD 350 GB Hard Drive, The files that normally consume a lot of space are movie files, picture files, music files & some others. Creating a link to your external to your desktop should make it fairly easy to access those files.
2. Do I just turn the external HD on every time I use the computer?
If you will follow #1, then you need turn on your external HD every time you use your PC since the files will be there and no longer in your main drive (C:).
3.will the data & stuff automatically load unto the external HD and not onto the computer?
No, not unless you have a software specifically for that purpose running and preset to automatically backup your system or files.. But then again back up means a copy of the original meaning the original 40Gb has still the files with a copy in the 350Gb. You are not saving space in the 40 Gb but merely replicating some of its contents.
4.Do I have to download from my computer hard drive onto the external one any data to make space?
Yes, but not only download, you need to "move" the files from the 40 to the 350 to make space.
Some suggestions:
a. Move all contents of your My Documents to the 350 and create a link/shortcut to your desktop;
b. Clean your Temporary files and your Temporary Internet Files as well as your cookies. This is best done using the Disk Cleanup command (in XP - Start/All Programs/ Accessories/System Tools/Disk Cleanup. Select what you don't need and follow on-screen instructions);
Hope that this be of help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 09, 2007
  • 32 Answers
You will have to manually move your old files onto the hard drive, and manually save any new files there. It's really pretty easy.
Open up My Computer and you should see at least two drives; one will be your old one and another one will be the new drive; open your old drive in one window, then the new one in another window (just open My Computer again and select the newer drive). You can then move files from one to the other my dragging while holding down the right mouse button; after you let go it will ask you whether you want to Copy or Move; select Move.
When you save new work, if you want it to save to the new hard drive just tell it to.
One thing to note though is that unless you've got lots of media files, most of what is filling up your hard drive is probably application software (i.e. the stuff that's filling up your Start menu). For any new applications you install, just make sure that you tell it to install to a directory on your new drive (for instance, if they normally install to C:\Program FIles\[Something], tell it to install to D:\Program Files\[Something], or replace D:\ with the letter of your new drive if it's something else). It is a little bit harder to move existing applications to the new drive, because some settings may not get carried over automatically. You can try to just copy the program files from one drive to the other tho, it should work in most cases. If it doesn't, consider backing up your settings for that program, uninstalling, and then reinstalling in a location on the new drive.
Hope that helps. Let us know if you have follow-up questions.
  • 556 Answers
The files are placed on the drive by you. Unless someone setup a special application files will not automatically migrate to another drive. You would not generally want them to because they would never be where you left them and be much harder to find. Primarily you will want to be moving data files and not application files (unless you uninstall from the internal drive and reinstall to the external drive) You can open my computer and find both drives -- you can drag/drop folders (containing only data, mp3s, videos, etc) between drives. I always like to check these moves by doing a right mouse click selecting properties on each folder separately to assure that an equal number of folders and files were copied before deleting them off of the smaller drive.
I emphasize again moving programs in this fashion will cause them to break. If you have large and seldom used applications you can uninstall them then using the installation process and media provided by the manufacturer then reinstall them choosing the external drive as the destination..
I hope this helps.
WD 1200BEVS
you can pull out the hard drive from box and connect it directly with computer see if it can recognized it, can not install drive can be due to problem with the disk FW or Hardware.
try to listen the drive carefully, is there any abnormal noise, beeps ??
hope it helps.
Apr 11, 2014 | Western Digital Scorpio WD1200BEVS 120 GB...
Tip
How to Recover Data from Western Digital Hard Drive
Part 1. Some common causes of data loss on Western Digital Hard Drive
Western Digital delivers high quality and high-performance hard drives in the industry. There is no doubt about the quality of these hard drives. But even the Western Digital hard drive users can lose their precious data stored on their hard drives. When something like data loss occurs with you, use the Western Digital hard drive recovery to recover your lost data. But you also need to learn the causes of the Western Digital data loss before performing the WD data recovery as it will help you prevent future data losses. There are various reasons that can lead to data loss on your Western Digital internal or external hard drives. For example,
  • Accidental deletion
  • Accidentally formatted Western Digital Hard Drive
  • Wrongly format or lost partition
  • Unrecognized and inaccessible drives
  • File system corruption
  • Eject or power off WD drive improperly
  • Virus attack
Part 2. How to Recover Data from Western Digital Hard Drive
External hard drives are more susceptible to data losses than internal hard drives as they are connected and disconnected to various computers in their lifetime. Data losses are as common on Western Digital external hard drive as on other hard drives. But data is not deleted from a hard drive permanently but only the link to the data is deleted from the register, making it inaccessible. The file will remain on the drive until it is overwritten by new files and data recovery software makes use of this principle to recover data from Western Digital external hard drive.
You just need to use the correct Western Digital hard drive data recovery that can help you recover your data safely from your Western Digital portable hard drive. We have found that Recoverit is the best tool for data recovery on WD external hard drive.
Why Choose Recoverit Data Recovery?
Recoverit is a propriety data recovery tool from the global leader in the Application software development - Wondershare. If you ever face data loss on your Western Digital hard drive, then you can use the Recoverit data recovery tool to get back any data was lost caused of accidental deletion, formatted, WD hard Drive corrupted or inaccessible, virus attacked and power failure, etc. It is the fastest and the most effective data recovery tool currently available in the market.
Step by Step Guide to Recover Data from Western Digital Hard Drive
First you need to simply download and install the Recoverit data recovery tool and then launch the Recoverit application on your computer after installation. You can choose Window version or Mac version of Recoverit according to your system. Here we take Windows version as example. After that, you can follow the steps below carefully to recover data from Western Digital external hard drive.
  • Step 1 Connect your WD external hard drive to the computer using suitable cables.
  • Step 2 At the interface of Western Digital data recovery application, select "External Devices Recovery" module to recover data from Western Digital external hard drive.
  • Step 3 On the "External Devices Recovery" screen, select the Western Digital hard disk and click the "Start" button. Recoverit Western Digital data recovery will start a quick scan on your Western Digital external hard drive for lost files.
  • Step 4 After the quick scan, you can preview the files that are found on the drive. If the files you want are not there, click "All-Around Recovery" to start a Deep Scan.
  • Step 5 Deep scan will find all recoverable files on your Western Digital external hard drive. Preview and select the files that you want to recover and then click on "Recover" button to restore them on your computer.
Part 3. WD external hard drive not recognized. How to Fix?
While using the WD external hard drive, users may go through issues like hard disk not recognized. A variety of reasons can result in a Western Digital external hard drive not recognized. Some of the common troubleshooting is discussed below.
1) Change the USB port or connect it with another new/available USB cable
There are common chances that your WD external drive fails to be detected to show up in your computer. In such case, you have to change the USB port or connect your hard drive by using a new USB cable. In general, the issues like WD external hard drive not recognized easily gets fixed by these measures.
2) Scan and clean up possible virus or malware
Virus attack is a serious issue when people connect their WD external hard drive to other computers. The hard drive gets easily affected when attacked by a virus, which hampers its functioning and makes you unable to access the data available on the hard drive. This makes it vital to remove the malware or virus available on your PC and WD hard drive. By scanning it with reliable anti-virus software you can easily remove the virus or malware.
3) Turn on USB Root Hub to make WD external hard drive recognizable
To troubleshoot the problem like WD external hard drive not recognized, you can turn on USB Root Hub to make it recognizable.
  • Select Start and type devmgmt.msc, then press Enter.
  • Open up the Device Manager and expand the USB controllers.
  • Now, right click on the USB Root Hub, select Properties and then head to Power Management.
  • Uncheck the box saying "Allow the computer to turn off this device to save the power".
  • Use this process repeatedly to turn on all the USB Root hubs displayed on the list. After that, restart your computer and the WD external hard drive should appear on your PC.
4) Check Disk Management
You can try checking the Disk management utility to see if the hard drive is showing up there or not. A drive may not be showing up because it hasn't been assigned a drive letter or assigned an already existing one. You can change the Drive letter of your Western Digital external hard drive to fix the issue.
To change the drive letter of the hard drive follow the below steps.
  • Press Windows + R to start the Run command.
  • Type Diskmgmt.msc and press enter to start the Disk management.
  • Now, find your WD external hard disk and right click on it and select Change Drive letter and path.
  • Then, assign a new drive letter to your WD external hard and click OK to save the changes.
  • After doing that, the following letter will be assigned to your Western Digital external hard drive and it will show up on the computer.
Part 4. Useful Tips to protect your WD hard disk
1) Do not add new data - Do not add any new files to the WD disk after data loss from Western Digital external hard drive. This can overwrite the files that can be recovered from the hard disk and you will permanently lose all the data. Hence, before you find out and recover all the lost data on your hard disk, stop adding new content on it. This will improve your chances of recovery.
2) Use Antivirus software - Regularly scan your WD hard drive with authorized antivirus software to help remove possible viruses from your WD external hard drive. By scanning and removing viruses from your computer regularly, your computer will be healthy and free from any file corruption that could lead to data loss.
3) Eject WD hard drive by using "safe remove" option - Never unplug or disconnect your WD hard drive abruptly as sudden removal may not give it enough time to save the status and lead to file system corruption. Always eject the WD external hard drive using the "Safe Remove" option to prevent data loss from sudden ejection.
4) Save the files to another hard disk or storage device after recovery - Always save the recovered files on another hard disk or storage device to ensure 100% recovery. This is because there is still a risk of data loss when you recover the files on the original location. Even if the drive itself has no problems, there is a chance of data loss when you recover files on the same location as it can overwrite the files that are to be recovered and you will permanently lose them.
No doubt Western Digital produces the best quality hard drives, but even they are as susceptible to data losses as other hard drives in the market. You may get really troubled when you lose your precious data due to virus attacks, accident deletion, hard drive corruption, lost partition and other reasons. In this case, you can use the Recoverit WD data recovery tool to recover data from an external hard drive, including Western Digital hard drive within just several clicks.
Best Way to Recover Data from Western Digital Hard Drive
on Jun 08, 2018 | Data Recovery Software Computers &...
Computer is dead, need access to hard drive content
your best bet would be to goto ebay and buy a kit which turns your hardrive into an external drive ..... determine what kind of hard drive it is and buy a kit .... ide or sata etc either way you will need to buy the coverter
Mar 29, 2014 | Western Digital Computers & Internet
Dead hd wd caviar 80 gb
Is the "dead" hard drive 80GB? or 500GB?
I presume you set up this hard drive as the second hard drive, or as an external drive. You can do these:
1. Disk Management (check the readablility):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
Click on the hard drive info, right click, and you can do some actions (format, expand the volume, assign a drive letter, etc.)
2. If necessary, test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
How do you install a new Hard Drive
DESKTOP COMPUTER: If you want to add another hard drive besides your already existing hard drive:1) Open the left side cover of a desktop computer with a screwdriver. 2) Locate two spare red cables ends (one for data transfer, another for elictricity) and plug them to your new hard drive (you can't do anything wrong, as the plug shape for each type is unique). Remark: If you don't have any spare ends of such cables inside your computer, buy SATA data cable: http://cgi.ebay.com/5-SATA-SERIAL-ATA-HD-DATA-HDD-SIGNAL-CABLE-RIGHT-ANGLE-/390263214964?pt=LH_DefaultDomain_0&hash=item5add801374#ht_1746wt_972 and 1 SATA power cable: http://cgi.ebay.com/4-pin-IDE-Molex-2-SATA-Power-Cable-Splitter-Adapter-/270716115788?pt=LH_DefaultDomain_0&hash=item3f07f01b4c#ht_3549wt_754. 3) Place the hard disk next to your already existing one and attach with screws so it won't move.
See this video: http://www.youtube.com/watch?v=Jbb9xrR49d8
LAPTOP COMPUTER: If you want to install a new hard disk for laptop, you normally can't have 2 hard drives - you can replace the old one (turn your laptop bottom-up, open screws at the bottom of it, open one of the smaller covers and locate your old hard drive in one of them) and reinstall the whole operation system (e.g. Windows XP) from your installation CD.
See this video: http://www.youtube.com/watch?v=pTCu331Rsac
EXTERNAL DRIVE: Or alternatively you can use it as an external hard drive (which is slower than the inner, though, because it connects to the computer through slower USB ports) - buy an external hard disk drive case:
In any case installing a hard drive is much easier than it seems, you virtually can't make a big mistake.
Mar 07, 2011 | Dell Computers & Internet
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
320 WD external hard drive
Could you be more specific? What do you mean "when I plug it into my computer?" Whay did you buy one..was there a problem with your existing one? Did you replace your old one or are you adding this new one to the other. Did you use the software that came with the new WD? Many details that you have ommited.
Justsayes
Nov 24, 2008 | Western Digital External USB 2.0 80 GB...
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
198 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
