Question about Midea MDC-45AE Dehumidifier
Need owner's manual for Westpointe dehumidifier MDC-45AE
Looked online for an hour - can't seem to locate one. Any suggestions?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Our dehumidifier model #MDC-25AEN3 or MDC-45AE or
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
  • 8 Answers
SOURCE: WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Posted on Oct 25, 2012
I need a new float for my westpointe dehumidifier model #MDC -25AEN3
This site does not sell parts or have anyway to look them up for you. Sorry
Oct 24, 2016 | Dehumidifiers
Why is ma dehumidifier compresor cuting off after starting it
this is a sign of a compressor problem : either the low gas pressure switch is shutting it off right after it starts or a high head pressure is stalling it off after it runs for a second , both of these conditions are not usually repairable by a homeowner and both are not good for a working unit
May 22, 2014 | Midea MDC-45AE Dehumidifier
Why does a dehumidifier go into defrost mode?
It gors into defrost mode if the cooling coils frost over. This usually occurs when the ambient air temperature in the room or basement reaches 65 Degrees F or lower. It's a normal operation and nothing to worry about at this point. Also, keep in mind that the air intake filter should be cleaned at least once every two weeks. This will help to reduce the frost on the cooling coils.
I hope this answered your question and thanks for choosing FixYa.
Sep 19, 2011 | Midea MDC-45AE Dehumidifier
How to replace or clean the filters also im trying to find a manual for this humidifier.
To remove and clean the filter: Turn the unit OFF & unplug it. Remove the water bucket and set it aside. Just under the front of the dehumidifier where you removed the bucket you will see a plastic handle. Pull down on it gently and filter will come out. Wash it with warm water and dry thoroughly, before reinstalling it in the dehumidifier. It is recommended that you clean the filter a minimum of once every 2 weeks.
As far as an Owners Manual is concerned. The following link will take you to it and you can download and print it for future reference.
http://shopping.netsuite.com/s.nl/c.618686/sc.10/category.44/.f
Hope this helped you. Please be kind enough to let me know. Thanks.
May 18, 2011 | Midea MDC-45AE Dehumidifier
The water won't run continuously out, instead the tank fill up. I have it set up to run continuous but the tank keeps filling up. I have the Westpointe dehumidifier.
Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
Hope this helped you to troubleshoot and solve the problem. Please let me know.
May 03, 2011 | Midea MDC-45AE Dehumidifier
What does p1 mean and how can I fix that? It's not pulling any water out of the air. I've lost my manual
It is low on freon and will not dehumidify the air. A local appliance dealer may be able to recharge it.
Dec 11, 2010 | Midea MDC-45AE Dehumidifier
I cannot find my manual for the Westpointe dehumidifier. I need to know how to fix it so that it uses a drain instead of the tank. It is set up with the hose which is directed to a drain. However, I...
Make sure the hose is clear. Did you put a hole in the attaching place for the hose? Most tanks come with no hole even though there is a hose place in the tank.
Jul 05, 2010 | Midea MDC-45AE Dehumidifier
Our dehumidifier model #MDC-25AEN3 or MDC-45AE or MDC-65AE only dehumidifies about 1 inch in the pan. There is about 80 percent humidity so something is wrong because it should fill it up. It has worked...
heatman101
Apr 09, 2010 | Dehumidifiers
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
Midea MDC-45AE Dehumidifier Logo
1,329 people viewed this question
Top Midea Dehumidifiers Experts
jasbo
jasbo
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
