Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
I have the sameproblem
Washer tub is tilted all the way to left and there is one screw in the tub dont know from where
  • 1,906 Answers
This is a snubber problem your tub in held straight by 3 springs they go from the washer frame to the bottom of the tub one spring is unhooked; bet it was held by the screw
Posted on Sep 07, 2009
Front left washer tub support rod has let loose - what is the best way to access that part ?
hi - remove the rubber stops front (round) i think screws under here, on the back are 2 plastic type of snap lock systems - unclip and gently tilt the top deck back onto something - enjoy...
cheers
Jun 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
How do you remove the top of the washer ? it looks like 2 screws which dont seem too accessable. The drum seems to be disconnected
To access the washer interior on these model washers, you need to remove the exterior washer case. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
With the washer case lifted out of the way, you should have full access to all the interior components.
NOTE: If the wash tub appears to be loose, double check your agitator bolt, first. If the bolt is tight, check your washer to ensure it is properly leveled:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
On an unleveled washer, sometimes the drum will appear to be tilted.
If you need further assistance, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Why does the washer basket tilt to the side
Had a similar problem, this might be the solution.
Unplug the washer, remove the two screws that hold the control panel to the top. Tilt the panel back, remove the plug going to the top and the two clips that secure the back to the case. Tip the case forward to release it from the front edge of the bottom frame and set it aside. From the front, you should see two springs attaching the bottom of the tub to the lower frame. The tub end of the spring is attached to a bracket that is screwed into the tub. In my case, the screw holding the bracket to the tub had vibrated loose, causing the centering effect to be lost. There is a third spring in the back if those two are intact.
Replace the bracket and screw, and you should be back in business. Best of all, it only takes time.
Feb 13, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
LAT5000AAW model Maytag washer will not spin or agitate and i dont know how to take the back or front of
I am not sure on this model, but see if you can take the top control panel off first. This should be held with a couple of screws, then tilt it back and this may give you acces to the screws holding the cover on. The outside cover should be one piece and it removes from the front. If this is correct on this model then you should only be left with a frame that holds the tub and the motor should be underneath the drum. I would check the coupling to the motor and make sure it is not worn out, this will keep the tub from spinning and agitating. You shouldn't even have to move it out or disconnet the water lines to do this.I hope I could help.
Nov 13, 2010 | Maytag PAV2300 Top Load Washer
Sounds like something stuck in the washing machine when draining
Something has become stuck in the drain pump.
1. Remove the back cover. The drain pump is in the lower left corner.
2. Tilt machine forward for easier access.
3. Unplug the pump motor power plug.
4. Loosen the hose clamp from the tub.
5. Remove the drain hose connection from the pump.
6. Remove the three screws securing the pump to the tub.
7. Remove debris from pump.
8. Replace pump.
9. Merry Christmas...
Dec 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Dial turned to the left
Hi wittoetr1,
Usually turning the knob to the left will only unscrew the timer knob. If someone has actually turned the timer left it is possible for the contacts inside the timer to bend causing lots of different problems. In this case the timer would need to be replaced. The part number is #3953146
The retail on the part is $98.23 and I do have these available for shipping. I can usually have this at your home anywhere in the United States within 1-2 days. I can ship for no extra charge. One other thing to consider before replacing. It is possible for a item like a child sock to be lodged in the pump and that would cause the water to pump out slowly and cause the problems you describe. I would check the pump first, then consider the timer. You can gain access to the pump by removing the cabinet to the washer. To do this you will see two phillips screws on the back left and right of the control panel., remove these screws and the control panel will flip up, then you can remove the clamps on the left and right sides that hold the cabinet to the back panel. Unplug the lid switch and tilt the cabinet forward and slide it forward. You will then see the pump directly under the tub held on the motor with two clamps. Remove the clamps and hoses but be ready to catch the water in a tub or get a heavy trash bag. Once removed check the pump for any obstructions. Please let me know if this helps and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Roper RAX7244KQ Top Load Washer
Kenmore Oasis washer LD
You need to pull the machine out and tilt it back to look at the pump on the right side. Need to remove carefully using a trash bag to contain the water. Then to examine for debris in the impeller. The second part is too remove the washplate by popping the center cover and removing the 7/16 bolt. Then to grasp the basket and lift sharply on it to pop out the washplate enough to remove. In the center you will see some phillips screws to remove, not the position of the pieces and line them up for reference. Next notice the tabs attaching the tub ring to the tub and remove the tub ring after loosing the recirculate hose clipped at the left rear corner. No with some patience the basket will lift out allowing access to a cover held in by two screws. You want to remove and inspect for debris and soda change.
Oct 13, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool LSR7233EQ0 Washer Leaking
just pull it off.on the control panel you will see two screws on the front or back back them out as far as you can then pull the control panel slightly forward then flip it back there are two gold clips on the body of the washer with a screw driver holding the handle pointing toward the back pop the two clips off but remember how they go as it can be tricky putting them back on if you don't then tilt the washer at about 45 degree's and pull it forward disconnecting any wires you see then take the body of the washer off and you can start working you will need a special wrench to get the tub block nut off or a small pipe wrench and hammer will do can get wrench fairly cheap at an appliance parts store now when you put washer cover back on tilt to 45 degrees and look down .the front of washer goes under frame and the sides go on top there are two rectangular slots that fit on tabs on the frame look close and you will see
Dec 31, 2007 | Washing Machines
Leveling a washer tub
you dont level the tub, level the feet on the bottom of the machine
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
