Question about Acer Aspire 5500 5570-2609 Laptop
I used The FN and F5 key and it worked
Now my lap top screen is huge? I tried the FN and F5 key to fix it and nothing? I toggled between the pictures. There is a lap top single then a lap top with TV and then just a tv. I tried all three. Tv gives me a blank screen and the other two keep the screen the same?
  • 1,498 Answers
Hi Trump,
What you are experiencing is the resolution settings of one device being used on the other.
Right click on the desk top
Click properties
Click the settings Tab
On the lower left increase the screen resolution (only a little at a time)
If you can read the screen that comes up, click OK.
If you can't, DO NOTHING. The original screen will return in 15 seconds
Click apply or OK
Hope this helps
Mike
Posted on Sep 07, 2009
  • 2,005 Answers
In windows go to: start;controlpanel;display;settings and, adjust your screen display
    President:
  • 2,600 Answers
Go to the point where you have a stable picture even if it is huge. Right click on an empty space on the desktop and scroll down to properties. Click on settings and increase the resolution a little at a time hitting apply and checking the display as you go. Keep hitting ok to the display settings if you like them. Find the resolution and display size that suites you.
Hi, I have a problem with Aspire 5570z The problem with 5570z is this: my Screen is blank with power and sound is on.
Unless the backlight has gone bad, try Fn+F5 and Fn+F6 keys to see if your display returns. Fn+F5 toggles to an external screen; Fn+F6 toggles the backlight on and off.
Aug 23, 2014 | Computers & Internet
When i try to run power point from toshiba satellite pro (to sony projector) I get frequency out of range. IT geek man has had it working in ffice by switching projector on first then lap top, but I cant...
are you using vga out on notebook ?
are you using vga in on projector ?
Turn on projector
hold down function key on notebook when turned on - FN button and press F5 - cycle through each mode by releasing f5 and pressing F5 again till you get CRT or CRT + LCD (while keeping FN pressed )
on data projector input source should be computer or vga
Jul 07, 2017 | Toshiba Satellite Pro L300 Notebook
How to view my lap top on my flat screen
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Apr 29, 2012 | Acer Computers & Internet
MY N5030 LAP LCD IS IN LAW LIGHT.CAN AS A SHADOW. I CONECTED TO EXTERNAL MONITOR IT WORKING BUT LAP DISPLY STILL AS
look khal sometimes most netbooks have a "hotkey" sequence to dim or brighten the screen on mine its Fn/F4 or Fn/F3 try this first or goto you manufacturers site and find the exact sequence of "Hotkeys" [remember Fn/F5 toggles between screen and monitor]!!
Good luck
Davey snake!
Jul 20, 2011 | Computers & Internet
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
I have an Acer Aspire netbook that I want to hook to a projector. I finally got the right cord to hook it up, but it will not display on the projector screen.
One of the F keys will toggle between the Laptop Screen and the VGA output - look at the F keys and see if one has a picture of a screen often F4 / F5 - needs to be used with the FN key
FN key+ F4 Key (Or which ever key has the symbol on)
It will toggle between <laptop screen only><laptop screen and VGA output><VGA output only> Not necessarily in that order
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
DVD video shows on laptop, but black on projector.
Assuming you are connected to the projector via the VGA port On the laptop, you will need to select the VGA output to work - there will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, but can be any of the F keys ----- (assuming F5 as an example ) use the FN key and the F5 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
Mar 22, 2010 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
When i hook my L455 to my sony hdtv the screen on the lap top turns black and the tv only says no signal in the pc mode. do i have to change some settings on my laptop
TV:- probably has a PC input - which is a VGA connector looks like this http://upload.wikimedia.org/wikipedia/commons/9/92/SVGA_port.jpg and then you select PC input on the TV to display whats connected to that port Laptop: - Now on the laptop, you will need to select the VGA output to work - thee will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, My Toshiba its F5 ---- (assuming F5) use the FN key and the F5 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
If you are not using a VGA cable and are connecting by HDMI cable - then there will be a F key to toggle the HDMI output - and you will need to select HDMI on the TV - NOTE: if this has a blue ray player and you are playing a blueray DVD, theres is copyright to protection to only allow one screen to be used, so you will need to toggle the laptop F key to just output from HDMI
Mar 22, 2010 | Computers & Internet
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
