Question about Cameras
Batterries discharged in its port - Cameras
  • 45 Answers
There is a short either in the battery pack or the camera. If you have another battery, test it to isolate the problem, else goto a camera store to test it, else seek eBay for a cheap battery replacement.
Posted on Sep 15, 2009
Iphone 4 wont charge or anything how can i tell if port is damaged
after 2yrs most batterries start failing, so probs needs replacing. use a 'air' spray to blow away bits. try different cables, but ports often go coz of in out all time. new magnetic cables help that one..lol
Mar 21, 2017 | Apple iPhone Cell Phones
Which connection is the suction and which is the discharge for this model pump?
Inlet/Suction is always the port that is Horizontal.
Discharge/Pressure is normally Vertical.
So to answer your question specifically about this pump: The answers are above.
For others that may have a pump body that rotates, the discharge/outlet/pressure can/may also by choice, be horizontally exiting. But the horizontal port for discharge will now be "Perpindicular" to the motor vs. "Parallel" with the motor.
A "Horizontal" port Parallel with the motor will always be "Suction/Inlet"
May 02, 2014 | Hayward SP3007 10AZ Super II Pump 1Horse...
Where are the ac ports on a 89 buick electra w/ 3.8 ltr engine
The easiest way is to follow your suction and discharge lines out from the compressor. The suction side is the larger line it will run from the compressor to the firewall on the pass side of the car. Here along the line you will find a receiver/drier tank and the suction port will be in this area. The Discharge line will run to the front of the car and out on the other side of the radiator. Along this line you will find the discharge port. Try this site idqusa when the site is working they offer a port location tool for most American cars.
Aug 25, 2011 | Buick Electra Cars & Trucks
I am trying to locate the low pressure port on my 2000 Saturn LS. there is no cap on the only visible and accessible port I see. It is located in the front of the engine compartment (passenger side) but...
The high pressure port is much larger than the low pressure port. It is impossible to hook a charging hose to the wrong port. If the charging hose is leaking, it is either because it is not clicked all the way on the port or the charging hose connector is defective.
The high pressure port is located on the discharge hose just to the rear (driver's side) of the A/C compressor.
Jul 10, 2011 | 2000 Saturn SL
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
I have an 24V electric mower.\i charge it
Either the connector between the battries and the mower are bad or the starter switch is bad, you know the wires between the batterries and the connector are good because you said the batterries charged just fine, so either between the connector and the motors, or the key switch has a break in its continuity, easiest way to test is connect the batterries directly to the motor to see if it works if it does connect before the start switch then after the connector the before the connector and keep moving up the connection wires until you fine where the problem is. Hope This Helps Don
Nov 08, 2009 | Black & Decker 19" Electric Lawnhog...
My mouse will work for about 5 minutes. then it disconnects from the usb receiver. the only way to make it work again is to turn off both the mouse and the receiver for a while then plug the receiver back...
I have seen this many times. What type of mouse do you have? Are they any other wireless devices in the same room?? These can cause trouble for you. Next you need good batterries. Some cheap Walmart type wireless products have this problem. You may need to remove and then reinstall you usb port. This is done under the device tab.
Oct 09, 2009 | Microsoft Wireless Notebook Optical Mouse...
How do i prime an onga pump from repressuring to primiing
Open the priming port at the discharge pipe. Close the discharge valve and fill the priming port with water until it is full. Power up and switch on the pump. While running, slowly open the discharge valve until the water
pressure gage at the pump is 20 psi. That will be the running pressure of the pump, and the maximum opening of the discharge valve.
Sep 27, 2009 | Plumbing
Dsc60 batterries run out quiclky
Test a different battery (one you know is good) on the camera and see if you still have the problem. If with you still have the problem then probably it is a short. Check first in battery contacts, if you can see a short there than it is an easy fix, otherwise you need to open the camera and test contact inside.
regards
Mar 14, 2008 | Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
