Question about Samsung WF203ANW Front Load Washer
Door Wont open on my Samsung J845 washing machine
Have tryd everything can't get behind the door to do it manually have my sons school clothes in it, is no yellow strip to pull to do an emergency release. What Can I do??????. Also the machine is now not working as it will not take the water from the tap to start the first cycle is this because of the door or is this another problem?
  • susannaingra Sep 07, 2009
    Thanks have tryd that but still no luck! think the door handle maybe broken as have had problems with it since i bought the machine and now the door handle is loose. The lock symbol appears on the panel may have to break door open to get clothes out as have found no other way to get the door open.Think i will go back to a top loader atleast when the machine breaks down you can still get your clothes out :-) thankyou for your suggestion.
These washing machines need an emergency release button in case shildren climb in and get stuck!!
Posted on Jun 17, 2012
    Brigadier General:
  • 4,090 Answers
Yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Posted on Sep 07, 2009
  • glebe Oct 14, 2010
    HAve had the same issue - door lock mechanism has broken. To resolve,
    1. unplug machine
    2. use a butter knife and push the mechanism between the handle and the cabinet while pulling the door open
    3. if this does not release door then ring repair person
    good luck
Ok just did it - latch swings towards you - you may need a coat hanger to PULL not push. i actually moved the coat hanger between the handle and the door - not between the door and the face of the washing machine. there is a small black sleeve around the metal piece - if you can remove that you will find an eye to poke the coat hanger through and feed enough coat hanger through - then pull. :) good luck
Posted on Oct 20, 2011
  • leo kaegi Oct 20, 2011
    sorry - amendment - if you fit the coat hanger between the handle and the door itself you push - if you fit the hanger between the door and the machine itself you pull. (the latter option here did not work for me)
The door on my washer wont stay closed and lock
make this steps and fix it. God bless you
First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further.
Oct 01, 2013 | Samsung Washing Machines
Siemens S 16 76 door will not open
Door Switch
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. Replace the main control is easy .
God bless you
Jun 09, 2013 | Washing Machines
Door is not unlocking
see the causes and fix it. God bless you
Door Switch
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Oct 16, 2012 | LG Washing Machines
My maytag front load washer door wont open and wont start either
see this causes and fix it. God bless you
Door Switch
http://www.appliancehelponline.com/washercontrolboard.html
Oct 15, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Unlock
Door Switch
Oct 02, 2012 | General Electric WCVH6800J Front Load...
Washer will reset timer and then unlocks door and water spills out what could this be
Door Switch
Sep 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
The soap socket in my machine wont open and the cover of the socket has removed from its place .. how do i open it ??
Door Switch
Sep 22, 2012 | Washing Machines
My Samsung SHS 1320 door lock display will not light up
see the causes and use the common sense.God bless you
Door Switch
Sep 19, 2012 | Washing Machines
Kenmore H2 Plus door won't open.
see the causes and fix it: God bless you
Door Switch
Jul 18, 2012 | Kenmore Washing Machines
He3t washer door is locked with clothes inside. Manual release doesn't work; and disconnecting DP21 doesn't work.
Possibly an item of clothing between the door and frame. Unplug the washer.
Press gently against the door latch while you pull on the emergency cord.
Dec 27, 2010 | Kenmore HE3T Washer
Samsung WF203ANW Front Load Washer Logo
4,534 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
