Question about Emerson Televison & Video
What does it mean when my television keeps
What does it mean when my television keep defaulting to the stand by mode what does it mean when my television keeps switching to the stand by mode
3 Suggested Answers
nfandres
  • 168 Answers
SOURCE: television troubleshooting
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Posted on Jan 16, 2007
techman007
  • 1112 Answers
SOURCE: my lg television switches back to stand by mode an have no pictur
Have the power supply checked for buldging capacitors on the power supplu, if you take off the back of the unit look near the power connector the goes from the Power supply to the main control board, you will find two capacitors that are starting to puff on their tops. The rating on the caps are 1000uf caps rated at 10 volts replace with 1000uf 16 volts caps instead.
Posted on Mar 03, 2010
KEEPS ASKING TO GO INTO STAND BY MODE WHY?
try resetting to factory default to neutralize all user inputted sttings which may be causing it to misbehave, if it persists in attempting to go into standby mode after being reset to factory default you may assume/ presume that a hardware fault is developing. If that corrects the issue job done
Sep 22, 2015 | Televison & Video
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
Keeps going into stand by mode
You didn't mention the make or model, but that condition is known as DC Offset, meaning a damaged amplifier. If you are interested in having your unit repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Hi my lg TV keeps blinking on the odd occasion , is there a setting to stop this
If you mean the brightness keeps altering check that it is not set to AUTO in the settings, this is the default setting to comply with the Energy standards. Switch it to OFF.
Nov 07, 2014 | LG 55 55LW5600 3D LCD TV
What should i do is my LG 42LC2RR's stand by light keeps blinking but it does turn on
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | LG 42LC2RR 42 in. HD-Ready LCD TV
LG 32FS2ANB keeps going into stand by mode
Recheck your remotes settings most likely it's turned on for stand by sometimes going into your settings and going back to it's default settings helps.
Jan 28, 2012 | LG Televison & Video
Help!i have just purchased an i-com R5 the manual keeps referring to the VFO,i know what it means but how do i know when the scanner is actually in the vfo mode??? deranged of swansea!!!
VFO stands for Variable Frequency Oscillator. This is the function that allows you to enter frequencies. It just means you are not in memory channel mode. You can get more info at the factory web sight and download the instruction manual for free.
http://www.icomamerica.com/en/products/receivers/handheld/r6/default.aspx
Feb 10, 2011 | Icom IC-R5 Handheld Scanner
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
Mar 29, 2009 | Panasonic Televison & Video
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
