Question about Samsung Televison & Video
I have a red blinking light on front of tv and it won't power on.
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound .
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like;
best of luck to you
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 07, 2009
3 Suggested Answers
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Posted on Sep 07, 2008
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Televison & Video Logo
688 people viewed this question
Henry  Thomas
Henry Thomas
