Question about RIM BlackBerry Storm 9530 Smartphone
My screen is black...the phone is powered on because i can hear the voice commands and the hard keys are illuminated but i see nothing
How to turn off voice command
Samsung Galaxy Grand Prime G530: How to turn off S Voice:
Hello.. to turn off follow the instructions below:
  • On your phone next to the Home button on the left side is a Menu key, tap that
  • Select Settings
  • Uncheck "Launch S Voice"
  • done
Jan 30, 2016 | Samsung Galaxy Grand Prime G530 Factory...
Tip
HARD RESET HTC Wizard / i-mate K-JAM / Cingular 8125 / T-Mobile MDA
While holding the Comm manager button and the Voice Command button, push in on the soft reset button (reset hole) once. Keep holding the Comm Manager and Voice Command buttons until there is a screen asking you if you want to clear all data. To commit, press the green send key
on Mar 10, 2010 | Cell Phones
How do I turn the voice command off on text messages
To turn of this setting:
1. From the home screen, press the Voice Commands key on the right side of the phone. The Voice Commands screen appears in the display. 2. Press the right soft key Settings.The following options appear in the display:
• TXT Msg Readout: Reads out the text in a TXT message. (Turn this off)
Jan 04, 2015 | Samsung SCH-U450 Cell Phone
How to execute voice command
right upside corner key is to be used as execute voice command....
Jan 10, 2012 | Nokia C5 Cell Phone
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
The voice command feature on my nokia 5320 don't work. When I select the voice command settings or music search or hold down "my own" key...nothing happens.
my nokia 5320 Display goes black(NOT WHITE) and i have to remove the battery to fix it! while screen in black,it still works! but I can't see anything!
how should I fix it?
Sep 18, 2009 | Nokia 5320 XpressMusic Cellular Phone
Keep hearing "command not recognized"
well. the problem is that you're probably hitting the command button where you sumbit voice commands like: call "mom".
its a stupid thing to put on a phone, and I've never seen anyone use it. but whatever, verizon's stupid.
again, the voice command key on the enV is the clear button. so if you hold it down, you'll hear the "command not recongnized, after you hear "please say a command".
your hearing it over and over again because you accidently hit it, and since you dont say anything after the beep it gives, it goes "command not recongnized". i dont think it says "please say a command" when its on vibrate, but i couldnt be sure.
hope i helped :)
Jul 20, 2009 | Verizon Communications enV2 Cellular Phone
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Voice command button
Hi Ronnierat322,
Voice Commands:
The voice command hotkey is the "Home" key. To start using voice commands, press and hold the Home key until you hear a beep. Say "Help" and you should get a list of available commands and how to use them.
Media Player:
While watching a video, press the zero key to switch to full screen mode. Please see the link below for additional details on this:
http://www.fixya.com/support/t1104583-voice_command_button
I hope these help.
Please let us know how things go!
Thanks,
Jonathan
Oct 04, 2008 | T-Mobile Dash Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
74 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
