Question about Emerson LC320EM8 32 in. LCD TV
My tv screen is not displaying a full screen and the setting is on full
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
Need facebook to display on the full 50" screen of a Vizo
You speak about the TV, but nothing about what it's connected to that is causing the resolution to be lower than you wish. If you are on any type of computer, you need to go into the video set up area and see what you can do to increase the display size. It's probably not the TV, it's more than likly the source.
Jack
Aug 06, 2014 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Lg led tv
thats called letterbox mode not postage stamp u need to take the tv remote go to menu button and press go to tv settings scroll down to tv display set up ok,select aspect ratio select 16;9 then ok the tv will be full screen
Jul 19, 2013 | Televison & Video
HDMI on Toshiba TV won't go full screen
press the menu and select picture settings and select the 16:9 aspect ratio to make a full screen.
Sep 16, 2012 | Toshiba 40XV645U 40 in. LCD HDTV
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Can't see full picture on TV
sounds like the dvd players set for differant picture format like full screen compared to wide screen settings. Look in the Menu of the tv as well as the dvd player
Apr 01, 2006 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Emerson LC320EM8 32 in. LCD TV Logo
227 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
