Question about Canon PIXMA iP5000 InkJet Photo Printer
Color is wrong
I am trying to print jpg and the picture has an orange tinge.  My cartridges are full of ink and the black 3e and Cyan are new when problem started.  i did all the software cleaning.  What shall I do? Otoshi
  • Anonymous Feb 02, 2008
    Color doesn't work when printing
  • Anonymous Feb 18, 2009
    When the quality is set to normal for paper plus or paper plus pro paper, my photos print great until the last inch or so, and then I get a yellowish pinkish stripe across the whole photo. Even the last half inch of the photo prints as it should. If I change the setting to plain paper the photos print fine, no streaks, but the quality isn't where I need it to be. This printer has worked flawlessly for 5 - 6 years!
  • Canon Master
  • 1,113 Answers
ARe you using Geguinn Epson inks? Aftermarket ones cause heaps of trouble, not all inks are equal. I suggest replaceing inks if they are not all Gen., the only parts it can be are the ink or ink head.
Posted on Dec 09, 2007
  • 5 more comments
  • Soulvisitor
    Soulvisitor Dec 09, 2007
    If you are using good ink, and you have done the cleans it will be the Head
    Here is a link to user manual
    QY6-0057-000 Printhead
    The iP5000 printer uses a QY6-0057-000 Canon Printhead. Printheads are classified as spare parts and as such do not need to be replaced as often as the ink tanks inside the printer. Over a period of time the resistors in the printhead fail and the image quality deteriotes.
    When should you replace the printhead?
    The printhead does not need to be replaced each time the ink cartridges are replaced, only when print quality deteriotes and a head cleaning fails to resolves the problem,
    Fitting the QY6-0057-000 Printhead.
    No special knowledge is required to fit the printhead and full detailed graphical instructions are included. Note: The printhead does not come with any ink tanks.
    After Installing your Printhead
    You may need to perform a head cleaning routine after installation and the print head will need to be re-aligned, refer to your user manual on how to do this.
  • Soulvisitor
    Sorry should of read Arey ou using Canon Ink...
  • Soulvisitor
    US link to printhead purchase
  • Soulvisitor
  • Soulvisitor
    The MIRACLE AIR CLEANING CURE
    for CLOGGED PRINT HEADS.
    This is how I do it on my Canon. You might be able to pull this off on an Epson. You can't on an HP.
    If you've put in a new cartridge and cleaned the nozzles several times, and the nozzle check STILL shows a clogged nozzle- I have found that after THOUSANDS (okay, maybe HUNDREDS) of prints, it may be necessary to spray compressed air through the WHITE flow-through delivery sponge. This is the little circular inlet that sits directly under the bottom ink cartridge hole in the print head. I.e.: Take out the ink cartridges and remove the print head.
    You'll see 6 1/4" holes into which the ink is delivered from the cartridge. Get a can of compressed air and spray from the cartridge side a few short bursts. HOLD A KLEENEX or toilet paper on the outside of the print head where the copper nozzles are- otherwise, you will get ink all over everything as the air cleans out the sponge inlets. Wipe off the outside copper nozzles, because ink will have poured out. No need to use any solvent, just a dry lint free paper. I've used 100% denatured alcohol at times- I don't suggest any other solvent for printer cleaning. Clorox, however, is the only thing that will remove totally inkjet ink stains from plastic housing, counter tops, your fingers- but don't use on important printer parts.
    Put your cartridges back in, run a clean cycle to get the ink running again, realign the nozzles, and VOILA- your printer will magically work again.
    If you have a big AC powered air compressor- (like for working power tools) this works even better- just CONTROL THE AMOUNT OF AIR- don't get crazy or you'll destroy the sponge inlets
  • Soulvisitor
    I beleive your printer has the same sort of head only using the 3 colours and 1 black
    link to above post http://www.neilslade.com/Papers/inkjetst...
    some more cleaning hints but I never do any cleanings, I replace faulty part with New.. if you just replace the print head then the job is done, not coming back Solved . If you start chasing the miriacle cure, you may be lucky but it costs time, frustration, mess and unreliability.
    Hope this helps
    S,
    Great inkjet site
    a LINK to the cure all, don't beleive them. I think the same company makes Hair growth serums too.
  • Soulvisitor
    More Cleaning Concepts
    Canon printers have a semi-permanent printhead. It's the 'holder' that the Canon ink cartridge (tanks) fit into. It can be removed fairly easily. Over time, it can and does become clogged, mainly from letting the printer set without use. You need to print both black and color at least once per week in order to prevent clogging and keep the ink flowing.
    Normally you can clear up minor clogs and streaking by running the cleaning cycle found in your printer's software utility. For quick access to your printer's utility (drivers): In your browser's address bar type: control panel\printers and hit 'enter' on your keyboard. This will bring up a page with your installed printer's icon. Place your mouse cursor over the printer icon and 'right-click' on it. When the dropdown menu shows, click on 'properties'. This will bring up the printer utility. Look for the 'maintenance' tab and follow the cleaning prompts.
    If the cleaning cycles don't do the trick in clearing up poor and incomplete output, don't give up and assume you'll need to buy a new print head (they often cost more than a new printer!). You can try the following as it will cause no harm: (we and many others have succesfully done this)
    Remove the Canon ink cartridge tanks from the printhead (tank holder) and seal them in a ziplock plactic bag. Set the removed Canon ink cartridge aside, preferrably propped upright. Next remove the print head, it snaps out. Use the kitchen or other sink and turn the water on so that it is running slowly and that it is warm. Hold the print head, bottom facing down, and cup your hand under the running water so that the water fills it up and flows into the the print head. This will flush the ink out of the printhead. You'll need to turn the print head over, bottom side up, and flush it that way as well. You'll see when there is no more ink being flushed out.
    You WILL need to do a final flush/rinse with some distilled, or purified water. This ensures that any risidual minerals or impurities of the tap water are flushed out of the print head. Set the print head on a paper towel to dry, drying time will vary. TIP: To expedite the drying process, shake the printhead vigorously as there is a fair amount of water retained after rinsing!
    Place the printhead (tank holder) back in the printer and reinsert the Canon printer cartridge. The printer should automatically do a print head alignment. If it doesn't, manually perform a "Printhead Alignment" through the printer's utility. Next, run the "printhead cleaning" cycle and print a nozzle check.
    Here's another, similar method:
    Open the lid of the printer and when the print head moves to the left, remove the Canon ink cartridge (tanks). You should then be able to easily remove the print head. It has the circuitry on it and on the bottom are the outlet nozzles.
    Get a small, shallow pan and lay a couple of paper towels in the bottom. Heat up (via microwave) enough purified/bottled water to cover the paper towels. Set the print head on the towels. You should see ink 'bleeding' out. Move the print head to several different spots (about a minute each spot). This will dissolve the ink clogs. Remove the print head and gently dab it dry on fresh paper towels.
    Place the print head back in the printer and insert the Canon printer cartridge. Run a print head alignment and a regular cleaning followed by nozzle check and test print(s). That should do it. If not, repeat the above procedure(s).
    If the above two methods don't quite do the trick, try this:
    Remove the Canon printer cartridges and printhead (cartridge holder) from the printer as instructed above. Get a small bowl, dish or pan, large enough to accommodate the printhead. Lay down a layer or two of paper towels in the bottom of the container to protect the printhead circuitry from contact damage.
    Make up a 50/50 mixture of ammonia and distilled water, about a pint will do. Heat the mixture up in the microwave for about a minute or so, not boiling. Slowly pour over the paper towels so that you have approximately 1/2 inch mixture total. Set the printhead (cartridge holder) into the container and pour some of the remaining mixture over the top, just enough to wet it good. Let it soak for several hours (3-4) or overnight. You can move it slightly to a different spot every hour or so.
    Remove the printhead and rinse thoroughly with distilled water. Shake it dry, set it on folded paper towels to air dry. Reinsert the printhead and ink tanks. The printer should do an automatic "Printhead Alignment", if not manually do so and run a cleaning cycle or two followed by printing a nozzle check pattern to check your progress. Repeat as necessary.
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
IS THERE A SPECIAL CARTRIDGE FOR PHOTO PRINTING. MY PRINTS COME OUT WITH A BLUE TINGE TO THEM my printer takes No. 32 black and 33 colour..
Sir,
Your problem is not of specially cartrigde but what you need is a special Paper which is made to print Photos and other colour full pictures. If you see is not this problem then there is chance that your cartridge is leaking from blue color point as there are three inks in color cartridge Red,Blue and yellow , than you need to replace you colou cartridge with new one .
Aug 28, 2009 | Office Equipment & Supplies
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
556 people viewed this question
old marine
old marine
