Question about IBM ThinkPad 570E Notebook
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
I loaded a new, Windows XP formatted IDE hard drive into an IBM Thinkpad 570e, and it's not doing anything. Is there a BIOS reset procedure or something I don't know about?
The computer recognizes it, I see it on the bios startup menu, but all I get after the bios menu is a black screen with a blinking cursor.
It's the only hard drive and it's already formatted so the cd drive shouldn't matter(?), though I cloned the HDD from a dell computer
  • 2 more comments
  • Donovan Merrill
    Donovan Merrill Sep 07, 2009
    I suppose I can't wipe it in the IBM the way it is? Seems too easy. I have to do that externally?
  • Donovan Merrill
    It doesn't even go that far-the XP disc hasn't even showed up onscreen. Maybe on another IBM 570E?
  • Donovan Merrill
    It's going now, thanks again!!!
  • Donovan Merrill
    It is, and I am. I wish I'd used that reasoning 5 hours ago. I appreciate the advice, and someone gave me the same just 15 minutes ago
    Brigadier General:
  • 4,090 Answers
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Posted on Sep 07, 2009
Testimonial: "Good advice, "
  • 3,153 Answers
Using the operating system from one computer in the way you describe will just not work.
You need to wipe the drive and start from the beggining with the drive installed in the computer / laptop you intend to use it in.
Then boot from the XP cd and start installation from there.
Testimonial: "I like a guy that just says what you need to hear, and no BS. Thanks!"
  • Project NOMAD
    Project NOMAD Sep 07, 2009
    The windows installation will offer to do it for you but let it do the FULL format (OK its as slow as a slug but it is better)
    tell it its a new installation and tell it your drive and when it come up select the format options
    you will be glad you did in the long run.
  • Project NOMAD
    and yes you can leave it in unless its a SATA drive in which case you need a floppy drive with the SATA drivers on it and then you press F6 during the dos part of the setup (watch bottom of screen)
    then in a few moments it will ask you for them
IBM Thinkpad G40 not recognizing replacement hard drive
my recommendation is to format the drive and see if that helps. do it via usb.
May 05, 2012 | IBM ThinkPad G40 2389 (2389HEU) PC...
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
IBM T41 bought a new 160G hard drive and formatted with Windows Xp and Office 2007 all seems fine but then the network card does not hit with the new install. Does something have to happen during new...
Go to IBM website and look for drivers for your computer model (T41) and locate the network drivers. (This obviously has to be done from another computer with internet access). Download and save the setup file to a flash drive and then run the setup on the IBM T41
Mar 14, 2010 | IBM ThinkPad T41 2373 Notebook
I can't load any OS on an IBM Thinkpad
Since both operating systems are failing to install, I would suspect that there is a problem with the installation of the harddisk (cable not securely connected) or the new harddisk is faulty.
Dec 08, 2009 | IBM Thinkpad I1400 I1500 2611
I can't figure out how to set my hard drive as "Master", I don't see anything like that in the bios menu. Where do I find it?
Hi Donovan,
In order to save you a lot of time and trouble, I wonder if you might comment me back as to what you are trying to accomplish. Answering a these questions will help too.
  • Please confirm we are talking about a thinkpad.
  • How many hard drives do you have
  • Does the machine boot
  • Does your CD work
If you have one drive and it boots, its master
Unless you have two Hard drives, the master / slave is sort of moot. There is also the CS option. This is why I need additional info.
Best regards,
Mike
Sep 07, 2009 | IBM ThinkPad 570E Notebook
I loaded a new, formatted IDE hard drive into an
If IDE drives are hooked to the same controller one must be configured in BIOS as Master, and the second as slave.
If there is only one drive, it should be set as master: Two drives on two different controller must be both defined as master.
Hope it helps.
I need to format an HDD for an IBM thinkpad 570e that came without one, and from what a lot of people say, it won't take windows xp pro. I don't have any other OS, so has anyone tried to do this...
Before formatting the drive ....
you will need to save your drivers on a cd/dvd disk if you dont have the original disks
Formatting the drive should be straight forward,
remove it from your machine and take it to another computer,
your IBM Thinkpad should be staight forward to reinstall even without taking your drive to another computer,I found this step easier tho....
after formatting this drive you could just insert to your machine and then reload your software from the beginning providing you have your disks,
You might have a password locked hard drive and or your bios may be locked also ,in this case replace the drive after which your new os install should give you access and functionality,
update your drivers on the internet and SP2 updates will give you hi speed usb 2.0 functionalilty.....
Good luck with the formatting,if you need help let me know,
have a great day
MISTERDJ
Sep 06, 2009 | IBM ThinkPad 570E Notebook
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
Thinkpad t20 trouble installing operating system
Three reasons why its not making it. One is a faulty hard drive, and even though you bought a new one it can still be faulty. Two is your Windows XP Disc is damaged but the most likely one is that your motherboards slot for the hard drive and/or more are faulty and is not working well. Run XP and choose 'Format Drive' and Install two partitions, one C Drive and D Drive giving each equal amounts and installing NTFS on one part and FAT32 on the other and see which one runs the best. If both fail, Replace your Hard Drive with the origional one where windows was shot and Format and do the same things as above with the partitions and NTFS and FAT32. If again it fails borrow another hard drive and again do the same things and again if it fails. Also since you said its difficult to make it to the part for partitions replace your CD Drive if the CD looks good and re run the boot disc. If all fails, replace your motherboard and give it all another go
Hope This Helps
Oct 08, 2008 | IBM ThinkPad T20 2647 Notebook
Reinstalling windows xp on a new hard drive - Thinkpad t30
You can go about this 2 ways.
First, if you have, or can get your hands on a copy of Windows xp; Load the windows system, then go to the IBM support site and download your drivers. Then you will be ready to go.
Secondly, call IBM support and get a set of recovery cds. You will have to have the information from the stickers that are on the bottom of the pc. I don't remember the exact cost, but as I remember it's about $54-55. Usually takes a couple of days to receive them.
Either way that you do it, you're going to wrap up a couple of hours.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 24, 2007 | IBM ThinkPad T21 2648 Notebook
IBM ThinkPad 570E Notebook Logo
175 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
