Question about Dometic RM2652 Refrigerator
Motorhome fridge not working on 12 volt - Dometic RM2652 Refrigerator
  • 32 Answers
If you are using an amonia cherged fridge, the amonia in your system normally cristallises after not yousing you fridge forf a long period of time. try to put the fride upside down for a few hours or a day and the turn it upright again. re connect your 12v to teh fridge and it will certainly work again.
Posted on Sep 07, 2009
5 Suggested Answers
  • 90 Answers
SOURCE: change gas/110volt fridge element to gas 240volt
I don't see the need to convert from 110 to 220. If your motor home has 220 circuits then you should be able to have it wired for 110. This would be just like in any residential home. Any 220 generator will have 110 available. 220 is just 2 hot wires, where 110 is one of those same lines and referenced to ground or neutral.
Ask an electrician if you are not sure how to wire it...
Posted on Jan 28, 2008
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
  • 127 Answers
SOURCE: I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Posted on Jul 05, 2009
The Motorhome is a fiat lifestyle. Can't get power for lights ,fridge is there a isolation switch.be grateful for any suggestions.cheers
look for disconnect if so see if working correctly or check fusible link for 12 volts and fuses in converter
Mar 17, 2017 | RVs
Fridge/freezer in a motorhome has stopped working on gas any help & advice would be greatly appreciated.
I am guessing this is a "three way fridge" 12 volt, 240 volt and lpg gas.
This is an absorbtion refrigerator and it uses heat to drive the cycle.
The things to do are;
Clean the gas jet, Piezio starter and thermocouple.
Also clean the rust, carbon and scale away from the heater tube and chimney.
Hopefully all will be good again
May 02, 2011 | Refrigerators
I just replaced the converter in my motorhome and everything works but the fridge won't work on house electricity, only gas ???
The old converter may have blown out the control board for your 'fridge. This is quite common if the voltage exceeds 15.5 volts, and when there is a ripple voltage (AC voltage component) riding on top of the DC voltage.
Gas / LP mode is the default for this fridge, a fail safe mode.
You can find the service manual for your fridge here.
Jul 08, 2010 | Dometic RM2652 Refrigerator
Where does the 12 volt dc power for the roof a/c come from
comes from your 12 volt battery that is installed in your RV/ Motorhome, which also runs some of your lights in the RV/Motorhome too.
Jun 19, 2010 | Dometic Rooftop RV Air Conditioner
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
414 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
