Question about RIM BlackBerry Storm 9530 Smartphone
Blind Phone i sat on da fone. everything started showing up backwards, so i rebooted. now i have a blind fone. evrything works but i cant see nothing
Sewing hems on curtains without stitch showing?
That would be a blind stitch but be aware that even blind stitches may still show. To be absolutely sure the stitches don't show, you may want to consider hand stitching the hem in place.
How To Sew Blind Hem Stitch
Feb 13, 2018 | Sewing Machines
Blind hemmer is "frozen" won't move at all. What can I do?
on a normal sewing machine this usually means the threads are all snagged up in a knot in the bobbin case. Snip your threads, wriggle the fabric out, remove all snagged threads and rethread the machine. I don't know if this will work with your blind hemmer.
Apr 25, 2013 | Sewing Machines
My sony ericsson play has a blank screen how do i repair or reset it?
ma f'in fone got ribbon problem x'play screen stays blank but everything working fine but I cant see whats going on !! I have tried to repair that **** for ma self but I couldnt open bluuudy one screw drive bcoz it was freaking damaged and it look like f'in old screw f'in chinese mn did not have freakin enough screws !! any idea for da bluddy old chinese screw out ? if dont no worry da phone will be sent to da f'in made in china were born in Japan **** ma LAN im done bluddy chinese run b4 I get da gun keep on run shoot ya to japaan.....
Jan 02, 2012 | Sony Ericsson Xperia Play
Which food sood i use to make an invisible hem
blind hem foot is good if you want to machine stitch a hem but not have a seam showing. it will have an adjustable piece you can move left or right with a screw. but blind hemming works best on straight grain and not on a curve like a skirt hem unless its a knit fabric that gives. to make a blind hem press the hem allowance up then turn the main garment piece back to form a Z shape. you then stitch along the hem side with your blind hem foot guidr running along the top fold and use the blind hem stitch which looks like three little zigzags then one big zig far to the left onto your folded piece taking a little 'bite' - this stitch shows on the right side when you press the top of the Z back flat. so you need to adjust the foot position and how wide the needle swings to minimise this stitch showing. hope this makes sense and helps you with your sewing.
Dec 19, 2010 | Elna 2007 Mechanical Sewing Machine
Lost everything visual, just audio.
Just enter the appropriate Menu-Setting (without a picture you´ve to do this "blind") - Press "Setup" - 1x key down (=video menu) - 1x key right (switch to sub menus) - 2x key down(=video format) - press select - key up (=interlaced) and press select again - finished!
May 05, 2009 | Televison & Video
My camera is blind
It is actually ccd problem.its generally due to mishandling of camera.and it repairable but bit costly.
Jan 25, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Storm 9530 Smartphone Logo
26 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
