Imageclass D380 X64 driver
I have an imageclass D380 laser printer - network shared on a 32 bit XP machine. I have a new X64 Windows machine and am having difficulty installing the correct driver to see the 32 bit connection. After installing what I believed was a cpmpatible driver, the status informed me that 'access denied'. Are there any appropriate X64 bit drivers for this primter?
Canon imageclass d880 info
What OS is the Vaio running? Canon has drivers for the 32-bit versions of Windows XP, Vista and Windows 7. The Windows 7 driver may work with Windows 8 32-bit in the compatibility mode. However, most computers with Vista and later versions of Windows have the 64-bit OS; the exception are some machines that came with 2 GB or less of memory when new. Canon did not create a 64-bit driver for the imageCLASS D880. To check your OS version, go to the System Control Panel. (XP, Vista and Windows 7: Start > Control Panel (in the right hand column) > System and Security > System. In Windows 8: press the Windows key + X and do the same steps.) Then read the version information, if x64 is included then the 32-bit drivers won't work.
If you do have the correct driver installed for your OS, try swapping your data cable and changing the USB port, if in use. Do not use a USB hub but a direct connection to the computer. Check the device manager to make sure that there are no problems with the hardware drivers. (As above, go to the control panel. Then either in Hardware or System and Security choose the Device Manager. From the Windows key+X, just choose the Device Manager.) Expand the section for the type of port you are using and look for a triangle with a red X or yellow exclamation point. Try updating or uninstalling the driver and then letting the correct driver load when you reboot the computer. (Check with Sony for the driver.)
Next try uninstalling the printer and removing the data cable from your computer. Then install the driver from http://www.usa.canon.com/cusa/support/office/imageclass_copiers/imageclass_d880/imageclass_d880#DriversAndSoftware . Then connect the printer to the computer when prompted to do so. Failure to install the Canon software first can interfere with the installation of the correct driver.
I hope this helps.
Jan 15, 2014 | Computers & Internet
Canon imageCLASS D861 - Windows 7 - 64 bit Is there anyway to update the 32 bit printer to the 64 bit OS?
Unfortunetaly, there is no solution for your problem, Canon did not made drivers for 64-bit OS's.
Alterantively
You can try download Windows XP mod for WIndows 7 or any other virtualization software, and try to install drivers on the virtual PC.
This should work for you.
May 09, 2011 | Canon imageCLASS D880 All-In-One Laser...
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Canon ImageClass D861 Need Vista 64 bit drivers
I don't think Vista is supported for this printer and if not doubt that it will be as Microsoft are bringing out a new OS to replace it.
Jul 28, 2009 | Canon imageCLASS D880 All-In-One Laser...
Network x86 driver support on Vista 64 bit OS (Samsung Ml-2510)
That's right. You'll have to install the XP driver on an XP PC, and share it to the other XP machines that way, or Install the driver on each PC individually -you can't share a Vista driver with XP PC's.
Mar 22, 2009 | Samsung ML-2510 Laser Printer
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
736 people viewed this question
jasbo
jasbo
