Question about Samsung SyncMaster 753 DFX 17" CRT Monitor
Dear Sir, My monitor is SAMSUNG 753DFX (17" White), my monitor green color problem (green color loss),pl. help me and give me solution. I am electronics familier. Thanking You, Arif
  • 205 Answers
Try to use windows color management scheme under properties of your graphic card setting. you can manually override the green red blue and gamma settings. In this way may be availing of desired result is possible.
Either way if you're familier with electronics, repair including possibility of shock hazard costs you more than the price of a new flat monitor.
Posted on Sep 07, 2009
Hi, I have Samsung 17' SyncMaster 753s with core 2 duo, 2 gb ram, intel motherboard and the problem is when I started my PC this morning after a 2-day break the monitor is having the screen like it has...
check you monitor controls!! check the monitor's contrast control and brightness controls. these are the push buttons on the front of the monitor. or they may be knobs that you have to rotate either left or right to adjust the image on the screen. if it is an lcd monitor then please refer to the user's manual for that monitor.
please try here for manual:
http://www.samsung.com/us/support/owners/product/753DFX
Aug 24, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Crt monitor gradually develops a yellow tinge after being turned on for a few minutes. It fluctuates annoyingly. It is about 4 years old. It is a Samsung SyncMaster 753DFX Crt monitor.
CRT monitors have three color "guns" in them - Red, Blue, & Green. If one of them is starting to go south you will have a tinge as you describe. To make sure it's the monitor, try connecting a different monitor. If the monitor is the problem, it's not worth fixing. Replace it.
If, after changing the monitor you still have a color tinge, you have a problem with your video device in your PC and you need to have it checked out by a PC Technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 22, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Sir i have 17' crt monitor and it gives display as shaking condition .. Could u give me some solution abt that ..
make sure u dont put speakers near ur monitor and any other electrical equipment that can generate magnetic field. (eg. UPS, stabilisers...).
May 19, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
No green color
Dears,
It happens due to either the PC settings or the monitor (hardware) settings. Would advise you to select menu from the monitor and do a factory setting do a quick check by using paint. The other option here is to access the color management in the control panel, there select the RGB values appropriately Hope this solution helps !!
Nov 09, 2009 | Samsung SyncMaster 700 (White) 17 in.CRT...
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 16, 2008 | Samsung SyncMaster 750S Monitor
Blurred images at start on samsung monitor
This is CRT Base Problem Simply Replace it
Thank You
Mar 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753 DFX 17" CRT Monitor Logo
226 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
