Question about RCA G36705 36" TV
Intermittent loss of sound
Sometimes we go days with no problems. then for no apparant reason there is heavily muffled pop and the sound is gone. Picture and channel select are great. The only fix is to remove complete power from the TV, wait about 5 minutes, plug set back in, and turn back on. Sound may last for the many days or it could drop out again after a few minutes. If it drops out, I have to leave it unplugged longer.
  • 232 Answers
Hpesoj the problem comes from the satellite in the sky, too many bits of data for your chassis, only fix involves adding a capacitor to the microprocessor, note that if the modification is done your closed captioning will no longer work, but it`s the only thing that will stop it other than un-plugging the ac cord waiting for a short time and then re-apply the cord, which you have already found out, any local tv tech should be aware of this "so called fix" give them a call, good luck, BMW Rider
Posted on Dec 12, 2007
Intermittent problem - speed dial 'drops out' sometimes for a few seconds, sometimes for a couple of minutes, then returns to normal operation
What year an model ford ? Electronic module clinch , lose or corroded connector or wiring , ground wiring etc... Do you know what voltage drop testing is ? Voltage drop test main battery cables , What is Voltage Drop Voltage testing fundamentals Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
watch these videos
Sep 09, 2016 | Ford Focus Cars & Trucks
I have a 93 Lexus ls 400 and it drives fine for awhile then out of the ordinary the check engine light pops on and the car all of a sudden losses power and won't acelerate any suggestions?
When the engine management system (EMS) detects a fault the car goes into "Limp Mode". This allows the car to be driven, but without any performance so you are not stuck at the roadside. EMS problems sometimes come up for no apparent reason, doesn't always mean there is an actual fault and it may just be a dodgy sensor. Unfortunately, you will have to get it checked out in this case because the car is virtually undriveable as it is.
Aug 17, 2015 | Lexus Cars & Trucks
1997 Chevy Lumina 3.1. How can I tell if the computer has failed?
Patrick: According to ECU "
Here are the most common symptoms of a bad ECU:
  1. Check Engine Light stays on after resetting
  2. Car was jump started on reverse polarity
  3. Engine turning off for no reason
  4. Water Damage or Fire Damage on the ECU
  5. Apparent loss of spark
  6. Apparent loss of injection pulse or fuel pump
  7. If your alternator overcharged the battery
  8. Intermittent starting problems
  9. Overheating ECU
  10. ECU has Broken Pins
  11. Loss of communication between the ECU and the Scanner
  12. A control module memory checksum error"
  13. ----------------
There is a really good article all about crankshaft positioning sensors:
I hope that helps you out!
May 11, 2015 | Chevrolet Chevy Cars & Trucks
Intermittent power steering loss, and engine power loss
Check battery connections and charging system.
Jan 31, 2014 | Cars & Trucks
My 42 inch flat screen was on and the all of sudden there was a big pop and the TV went blank. I could hear it clicking inside after this happened. Pulled the power plug to stop it. What caused the big...
It sounds like one of the Electrolytic Capacitors in the TV has gone, this can be caused by voltage fluctuations, Ambient Temperatures around the TV and sometimes they just fail for no apparent reason. If you are handy with some basic electronic tools you could open the back of the TV and you would possibly see the remains of the blown component as bits of paper like material around where a capacitor used to be.
Oct 25, 2010 | Samsung Televison & Video
Intermittent sound with cbl/sat. Sometimes sound
Your receiver is HDMI version 1.1,1.2 or 1.2a and just don't work with anything to be honest with you. It's an HDCP (copyright Issue) and 5v pass thru issue. and the list goes on. If you can, just run HDMI directly to the TV and optical or Digital Coaxial to your receiver for audio and all will be well again. If you need more help, just post a comment and I will gladly help some more
Jun 24, 2009 | Onkyo TX-SR875 Receiver
91 integra yes it muffled when gas is pressed and hesitates also
sometimes a clogged catalytic converter can cause loss of power and make it hesitate . . anymore symptoms that u think it may be causin that? let me know i also own the same year integra
May 29, 2009 | 1991 Acura Integra Hatchback
Philips 28pw6515/05
Hello dan5260,
Your audio processor might be going bad or at least one of the capacitors might had malfunctioned.
We are actually not talking about much expense in fixing this problem. At my shop here how the pricing would go:
Parts: $20.00-$30.00
Labor: $60.00 per hour (1 hour limit) Total $120.00
Starter Fee: $30.00
So total will be about $170.00 - $180.00
This is just an estimate based on my shop, your local shop might charge more or less.
I hope this helps,
Thank you,
Oct 03, 2008 | Televison & Video
Philips 28pw6515/05
Good old cash generator, make one wonder why they are there in the first place doesn't it.
Sep 16, 2017 | Philips 28PW6506 28" TV
Intermittent audio output
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Sep 10, 2007 | Denon AVR-3300 Receiver
RCA G36705 36" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
