I have a battery light and a chord light but when i try to press the on button it does turn on
  • christoph49 Sep 07, 2009
    THE ON BUTTON WILL NOT TURN THE LAPTOP ON AT ALL
    President:
  • 3,278 Answers
Remove the battery and try to power on with the power adapter connected. If OK, the battery is faulty.
Hope this helps.
Posted on Sep 07, 2009
Could you please suggest the best way to turn my toshiba on.it has not responded when I push the power button.I have tried removing the battery and putting it back in, as well as checking the power chord...
When you take the battery out, don't just put it back in, leave it out and press and hold the power button for about 30 seconds then put the battery back in and try turning the laptop on by the power button. If it still will not power up after that you may have RAM / motherboard and CPU issues which can be hard to diagnose without extra parts laying around.
Chris
Sep 24, 2011 | Toshiba Computers & Internet
The print cartridge can not move
turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Mar 26, 2011 | HP Officejet 5610 All-In-One InkJet...
When I press the switch button the power led comes up but nothing shows on the screen, the cpu fan rolls for few few seconds and stops
try to do a power drain.... unplug the power chord... then remove the battery.... while the battery is out... press and hold the power button for 30 seconds.... then put the battery back in and then the power chord.... then try booting it up.... if it works well and good.... if it does not and u see all the lights but not anything on the screen, try with an external monitor just to check if its an issue with the lcd screen.... if its working on a different monitor, u know what to do... take it to a service center....
again if nothing works... dont wait.. take it to a service center
Mar 18, 2011 | HP Compaq nc6000 Notebook
Computer won't turn on
try removing the battery and then plugging the laptop in. when you plug it in make sure that the light comes on that shows you the laptop is charging. If it doesn't wiggle the power chord inside the laptop till it does light up. Then press and hold the power button. With these Toshiba Ive seen that you may have to press pretty firmly. Hope this helps :)
Dec 27, 2010 | Toshiba Satellite L505-S5966 Notebook
My HP Officejet 6310 makes a squealing noise when printing, like the roller needs oiling-any suggestions on what to do?
turn off the printer..connect the printer to wall outlet..and try to make a copy..if its still the same..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold OK and CANCEL button together..
3)while pressing these two buttons plug in the power chord to the back of the printer..
4)after you plug in the power chord do not release those two buttons..
5)keep pressing those two buttons till the screen goes blank..
6)once the screen is blank release the buttons and turn on the printer..
7)wait for the printer to get initialize..
8)once the initialization is complete..try to make a copy..if the printer is still making noises..then machine should be replaced..
let me know after you perform these steps
Mar 10, 2009 | HP Officejet 6310 All-In-One InkJet...
Powering up a dell d610 laptop
remove the battery and start the machine on AC power only, see if this helps
keep us informed
regards
Nov 24, 2008 | Dell Latitude D610 Notebook
Printer problem
hi,
have you tries inserting new set of ink cartridge???
try this...
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
agnel
Mar 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Power on
u go to acer service center
lot of acer service center in all areas
Oct 22, 2007 | Acer Aspire 9500 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
