Question about Kenmore Washing Machines
My washer stops with 1 min. left on the cycle. It
My Kenmore washer model 44082 stops with 1 min. left on the cycle. It just displays 1 min.
    Habit-Forming:
    New Friend:
  • 3 Answers
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Posted on Dec 02, 2017
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
Oct 14, 2014 | Washing Machines
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Replace the door lock mech if the wiring is ok
Oct 11, 2009 | Kenmore Washing Machines
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Kenmore Front load washer didn't complete the cycle.model #44082
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
Jul 06, 2017 | Kenmore 44102 Front Load Washer
Kenmore washer stops
if washer resumes operation when left alone after 30-45 min suspect motor overheat ..also could be bad timer contacts or connection on motor end at plug
May 20, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
