Yesterday our washing machine started leaking from the hose connection at the back of the washing machine. Is this just a new seal needed or something more serious?
  • Washing Mach... Master
  • 8,220 Answers
A water hose is going bad. Probably the hot water one. Better replace it before it pops.
Posted on Sep 07, 2009
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
After washing cycle starts, tub starts to leak. I tilted machine backwards and can see that water is from the drum itself but cannot tell if leak starts from top or not.
It is extremely rare for the leak to come from the drum itself. It usually comes from the fill hose at the top. The hose connecting the drum to the drain pump, or the door seal. There is access from the back of the machine, or you can take the screws off at the rear on the top of the machine, and the whole top will slide off.
Mar 10, 2011 | LG WM2301HW Front Load Washer
Washing machine leeks and doesnt complete cycle
When the washing machine starts leaking water all over the floor, you face a tough choice. Either call a service technician to fix the problem or purchase a new machine. Both decisions are expensive. Most service technicians charge $50 to $100 just to walk in the door and diagnose the problem, and labor expenses can quickly accumulate. After receiving the final bill, you may even wish you’d replaced the machine!
TIP: Make sure the water on the floor isn’t the result of a plugged floor drain. It happens!
There are two types of washing machines: belt drive and direct drive.
If you open up the cabinet and don’t find any belts, then you’ve got a direct-drive machine. Repairs are similar for both machines, but generally easier on the direct-drive unit.
The following photos are from a belt-drive washing machine. If you have a direct drive, refer to your owner’s manual or diagrams (see “Buying Parts") for brand-specific details.
First, Replace Leaky Supply Hoses
The first step is to locate the source of the leak. Empty the washing machine, move it away from the wall and start the fill cycle. Look for drips around the water supply hose connection at the back of the machine while it fills with water. Shut off the water and replace any old, heavily corroded or rusted hoses with new ones. If the hoses are in good shape, replace the internal washers only. Special no-burst hoses ($10), regular hoses ($6) and new hose washers ($2 per 10-pack) are available at home centers and hardware stores.
Turn off the water main or shutoff valve and unscrew the supply hoses from the back of the machine with an adjustable pliers. Pry out the old hose washers with a flat-blade screwdriver. Install new gaskets in both hoses and reconnect the supply lines.
Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Thank you Sir, Have a nice day.
Sep 17, 2009 | Whirlpool Washing Machines
Leaking. hose connections have been checked.
We just repaired my son's washer yesterday. Same problem as yours. It was a tub seal.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Washer top
The following link should give you the steps necessary to remove the exterior washer casing to inspect the interior:
http://www.fixya.com/support/r397092-replacing_water_pump
The instructions are for replacing the washer pump, but the steps to gain access to the interior are the same. If the leak is coming from the FRONT of the washer, check the pump and drain hoses for loose connections. If the pump is leaking, it is not repairable (sealed unit) and must be replaced. If the leak is coming from UNDER THE WASH TUB, this is a symptm of a leaking tub seal, or cracked tub. This requires removal of the wash basket to replace either part. If the leak is coming from the SIDE of the wash tub after it starts to fill, check the air dome hose to ensure it is still attached and not leaking. This is a small air hose that connects to the side of the wash tub and runs to your pressure switch. It sometimes becomes loose or disconnected and leaks. If the leak is coming from the BACK of the washer, check the fill hoses and water inlet valve hoses. I hope you find this information helpful. If you need further assistance, please let me know.
Oct 19, 2008 | Kenmore 15864/15862 Top Load Washer
Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Aug 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
