Question about Samsung Televison & Video
I have Samsung CS-21K40ML flat screen color tv and having a problem that the display is rotated down from left about 2mm. the news strips appearing from left to right are cut by half in start and become visible as they pass towards right side.
hardrocko
  • 1476 Answers
SOURCE: Color rainbow in picture
Your problem sounds like someone got a magnet too close to the CRT. This can be removed with a degauss coil (which you probably do not have) or it will eventually go away if your built in degauss circuit is working. Everytime you turn on the set the circuit degausses the crt so colors can be displayed properly. If the circuit is not working you will need to have a tech repair it.
Posted on Jun 23, 2006
techman
  • 3130 Answers
SOURCE: Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Posted on Mar 27, 2007
chrispurs1
  • 372 Answers
SOURCE: Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Posted on Oct 30, 2007
  • 71 Answers
SOURCE: DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Posted on Dec 10, 2007
SOURCE: HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Posted on Apr 06, 2008
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Sep 19, 2013 | Samsung Televison & Video
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My kids were playing the Wii and accidentally hit the power button on the tv. When it was turned back on a circular rainbow effect from the center to the outside of the tv appeared. I tried messing with...
it is an lcd flat panel i assume.. if so the display panel has been damaged beyond repair.. most likely by a body hitting it.. sorry for the bad news..
Nov 15, 2009 | Samsung TX-R3080WH TV
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
I have a Samsung LN32A550 LCD TV. When I turn on my TV, there is a dark rectangular strip 3 1/2 inch in width on the left side of the screen. It is not that obvious, but noticeable. The strip does not go...
One thing you can try IF you know how to work with electronics.
Unplug and remove back cover. Remove the metal cover on the LCD Controller card. (it near the top of set) You may have to disconnect the top of the "H" frame to get to it. Disconnect and carefully re-connect the flat ribbon cable for the left side of the display. (The right side is good so don't touch it.) The connector for the flat ribbons will flip up to release the ribbon. The ribbon is short so this is tricky to do right. You may need a small plastic tool to help. Dont' break the connector. With the card back in place check if the band is still present. If vertical lines appear on the display, unplug and reposition the cable again until they are gone.
Don't touch the contacts on the connectors.
Re-assemble the set. No parts should be left over !!
LCD Controllers for this set are for sale on eBay if need.
Feb 17, 2009 | Samsung LN32A550 32 in. LCD TV
Black line down the left side of the screen
This is a bad panel. The panel is very expensive to replace. It would be cheaper to buy a new tv. Sorry about the bad news.
Nov 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Televison & Video Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
