Question about Polaroid TLA-01511C 15 in. LCD Television
To use as monitor, what cable do I use? - Polaroid TLA-01511C 15 in. LCD Television
Hello Dear,
my name is Nancy,how is your health?
i view your profile today at (fixya.com) and i like it
please i really want to be your good friend, i hope
that you will grant my request with good faith,please
I will be very happy If you can get back to me
through my e-mail (nancykind20@yahoo.com)
So we can get to know each other better and exchange
our pictures and also tell you more about me OK
Yours Lovely,
Nancy
Posted on Dec 28, 2011
  • 92 Answers
Male VGA to Male VGA (15 Pin D-Sub Male -> 15 Pin D-Sub Male)
Posted on Sep 07, 2009
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
When I turn monitor on it just says "No signal" and goes off. Help!
Power off the monitor.
Unplug the video cable from the monitor.
Power on the monitor.
You should get some sort of display on the monitor saying "no signal" or something similar as you have already experienced - if so, good.
This means that your monitor should be OK.
Next, power off the monitor again.
Plugin the video cable back into the monitor, make sure you screw it in all the way.
Unplug the video cable from the back of your computer, inspect if for any damage.
Plug the video cable back into the computer, make sure you screw it in all the way.
Power the monitor on.
Any picture?
No? Make sure the computer is turned on and is not in any sleep or hibernation mode.
Still no picture?
Try the monitor with the same cable on another known working computer.
Still no picture (or you don't have another computer)?
Purchase a new video cable or swap video cables between monitors if you have another monitor.
Also make sure that the monitor cable is not crimped and it looks in good working order.
Jun 16, 2011 | Office Equipment & Supplies
My monitor keeps turning yellow constantly. How do i fix this problem?
-check the monitor cable (vga cable the one with blue connector) for broken pins
-if there are broken pins replace the cable
-if not try another monitor cable or try the monitor to another cable
-if the monitor still turns to yellow after trying another cable or connecting it to another computer to problem could be with the monitor or the vga card
Nov 24, 2010 | Computers & Internet
My monitor color is being dimmed automatically after few minutes of start. it is 6 months new.
-kindly check the vga cable or the monitor cable if its properly connected
-you can disconnect and reconnect the monitor cable to check if it could help
-if not you can try another monitor cable or you can connect the monitor to another system to check if its the monitor or your graphics card
Nov 22, 2010 | LG W1953TPF 19" Monitor
Check video cable on computer
On the monitor unplug the power and video cable. Plug the power cable in, and then the monitor cable. Power off your computer, then turn on the monitor. After you power on the monitor, turn the computer on.
Nov 08, 2010 | HP 2009M Monitor
My pc does not give display ? Why
Time Required: Testing a monitor could take from a few minutes to much longer depending on the cause of the problem Here's How:
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
  5. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    • If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
  6. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
  7. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
    Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
  8. Replace the monitor.
    WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it.
Aug 02, 2010 | Dell Dimension 2400 PC Desktop
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    How do i connect my cable tv to this monitor?
    It all depends on what your cable box output is.
    This monitor appears to support a standard cable cord input. So in essence all you should have to do is connect a cable cord from your box to your monitor.
    Oct 03, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
    Sound
    Is your monitor SUPPOSED to have sound? Apart from the power cable and the monitor cable, if it is a monitor with speakers, there should also be an audio cable. So 3 total. If it has a mic too, 4 cables. The audio cable is normally green and the mic cable pink.
    Most monitors don't have sound though, and the ones that do, sound crappy. So unless you just plan to hear Windows dings, get some cheap speakers.
    Sep 20, 2008 | Acer AL1916W 19" LCD Monitor
    Polaroid TLA-01511C 15 in. LCD Television Logo
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
