Question about Panasonic Lands Phones
Broken Answering Machine Cassette Tape
The cassette tape (incoming messages) in my previously trustworthy Panasonic Answering Machine (model KXT1427) is stuck. The right spool keeps whirring & and I can't get the cassette out b/c some metal is sticking out into the cassette preventing me from lifting it out. The great repair shop I took it to in SF years ago has closed down. How can I fix this? If not, know any great repair shops around South SF Bay Area, Calif.? Thank you!
  • wahinewahine Sep 07, 2009
    Hi Robert,
    Thanks. I had tried unplugging it, to no avail. Tried doing as you said and unplugging the phone line, but it still doesn't work. When I put just the AC power line in, there is a constant "whrrr..click..whrrr..click..whrr..click" sound and the mechanism keeps trying to move the cassette tape. Now this is after this machine has had solid, dependable performance for years, which is why I like its simple model. Any other suggestions? Thank you!!
    Brigadier General:
  • 5,158 Answers
I believe all you need to do is unplug it or take it out of answer mode. keep in mind you have to unplug the phone line as well as it will get power from it.
robert
Posted on Sep 07, 2009
Model PV-D4732. How can I get cassette to eject?
When you press EJECT, the tape has to be withdrawn into the cassette and the shutter closed before the cradle can be lifted to clear the spindles and allow the cassette to be shoved out. You will have to disconnect power and remove the cover to expose the complex inner workings and I suspect you will find a tangle of tape or a broken tape. Some careful work with appropriate tools will allow the tape to be stuffed back into the cassette or (worst case) cut out. You can apply power again and you may be able to observe the sequence of ejection operations before reinstalling the cover.
Dec 23, 2015 | Panasonic Televison & Video
As machine window flashing 88 and clicking
Disconnect power cable and remove battery, it should reset
Jul 18, 2008 | AT&T 5840 5.8GHz...
Can I retrieve an erased greeting message on a panasonic answering machine model #kx-TG9341T
Unfortunately the news is not good. The answering machine does not have tape storage. Everything is stored on a memory chip. Anytime you re-record the incoming call greeting, you overwrite the previous greeting. Sorry.
Nov 01, 2014 | Lands Phones
Why won't answering machine work
Hi Julie,
If yours is a cassette or other type tape recording answering device - check that the tape hasn't broken. If a digital recorder / or cassette tape type, be sure that the recorder isn't full or that you're at the end of the tape. Erase / delete old messages to recapture recording space. If you need more help, please provide the model number of your device.
May 19, 2014 | Panasonic Lands Phones
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Can a tape be recorded
the machine that youare going to play the tape in you should use the video out and the audio out to the video in and audio in on the machine that you are going to record on or tape on which ever you want to call it.
Mar 07, 2009 | Panasonic AG-520G 20" TV/VCR
I got Panafax UF-595 and this fax keeps saying "check cassette info code=011" and does nothing else. What am I supposed to do to make it work?
There is a small plastic tab broken off of the front of the paper cassette.
Remove the paper cassette
remove the rear brown tray
remove the toner
set the machine on it's back side
wad up a small piece of electrical tape
stick the tape in the black U-shaped photo sensor at the bottom left corner of the machine to cheat it.
Dec 10, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Phonemate 8800 answering machine (micro cassette - not digital). Turns itself off and shows "E3" in window. What's wrong???
"E3" says "Incoming message tape is missing, stuck, or broken. Replace the tape" I had the same message. My drive belt broke. I put a rubber band in it's place and all works OK now. I need to order a new belt, but haven't yet.
Jul 31, 2008 | Lands Phones
Lands Phones Logo
211 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
