Question about Mitsubishi WS-65807 65" Rear Projection Television
Attempt to turn on greenlt comes on for 2 secs then shuts off
Thre was no warning. Unplugged for hours no results.
Air blown then vacummed no results.
No leaks on circuit board.
Which portion of circuit board is most likely in need of repair?
  • 4 more comments
  • rdbjrmd Sep 07, 2009
    Thank you very much
    2 blinks pause and 2 blinks.
    Where on the board is most likely the problem?
    Thank you! The pico fuses "look" okay. I may have ordered the wrong chips today, the STK393-040. Where are you located? Otherwise I think i will attempt repair myself. Many thanks
    I am interested in your step by step instructions.I have managed to remove the circuit board. I am ordering the correct chip. stk393-570
  • SD Tech
    SD Tech May 11, 2010
    etower.766@netzero.net
  • SD Tech
    If it is a Mitsubishi WS-65807 IT uses two STK-392-570 CHIPS; the fuses can be tested just like a normal fuse; I am in San Diego, California
  • SD Tech
    WS-65807? if green light comes on for a moment and goes off--engage the sets self check: hold on the front of the set MENU and INPUT buttons for 5 seconds and release---set should blink a 2 digit error code(power light) for example ---2 blinks, a pause and 2 blinks---it will repeat it about 10 times--let me know what the error code is and I will tell you what you have---2, then 2 is the most common SD TECH
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
WS-65807?The most likely problem is one or both of the fuses that protect the 2 convergence chips are blown. The set detects no voltage and shuts down. This set uses 2 stk-392-570 convergence IC's; I have step by step start to finish instructions for this repair along with photos that show the fuses and protect resistors.
If you can do the repair yourself---the fuses (called pico fuses) should be checked first---if either of the 2 for the convergence circuit are blown---you have to replace them and BOTH chips.
If you are not able to do this repair yourself, find someone in your area who has done this kind of repair; any good tech can do this repair in your home--takes about an hour. Most shops will try to charge 300-400 for this repair-----I do lots of them here for 200-250 total. If a shop says it "has to go to the shop", keep looking.
I do this here for free so if this information has been helpful take a minute to give me a vote here.
If you have any questions reply to this post.
Posted on Sep 07, 2009
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
I have an Hp pavilion slimline s3100n pc and after a while, it just shuts off with no warning whatsoever. When I try to turn it back on, it just shuts right back off. It's like I have to wait for it to...
Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
Aug 18, 2010 | HP Hewlett Packard Pavilion Slimline...
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
I turn the laptop on after about 30 secs it turns itself off. Acer Aspire AS5520. Some vendors are saying it is motherboard problem and some are saying it is CPU problem. and you have to replace it.
its probly 1 of 2 things the battery or its over heating see if you can feel any air flow from the fan vent it may need to be blown out with some compressed air or vacume
Jun 05, 2009 | Acer TravelMate 5520 Notebook
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
HP Pavilion power up
You could have overheating problem
remove all plates from underneath that allows access to internals and blow out using a can of compressed air (from Radio Shack shop or similar) and ensure fan vent is clean and clear. then try it with all plates off if OK replace plates and try again. If still shuts down laptop requires stripping completely to clean
Oct 15, 2008 | HP (5185-6477) Motherboard
Magnavox TV won't turn on
There is a capacitor on the main board the goes leaky and will prevent the tv from turning on. If you know how, you can check the caps near the flyback transformer and find the leaky cap if you are not a tech and don't have a ESR meter it is beter to have a trusted tech to do the repair. Depending on the shop cost should be around $79-$89 depending on if you take it in or have them do a home call.
Jul 19, 2008 | Philips Magnavox 27MS343S 27" TV
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
