Question about Motorola Mobility RAZR V3i Cellular Phone
Is there any way to increase the message memory?
what kind of may be downloaded on motorola v3i handset?
Sms memory of moto razr v3i
my cell motrola v3i showing memory full in just 25 sms can u tell me ho to increase memory
Sep 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Skins
I only use funformobile.com. You can choose wallpapers, ringtones, screensavers ect. It's all 100% free. You just sign up, give your phone model, number then when you find one you like just click on 'send to phone'. Then it comes to you in a text message. It's so much fun! Good luck. If this helps you plz rate this as 'fixa'. Thank you kindly.
http://www.funformobile.com/
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Things i dont know in using motorola v3i
for erasing messages you should click the button that is in the middle, at the top of all buttons of the phone.. then you will see the options you can select, between them, there is "erase", you can choose to erase them all, or just the message you were reading..
don't know is themes can be dowloaded.
for the pictures it is quite the same, if you go to options, using the same button, then you can choose something like "use different memory device" and if you choose that, you can choose between the intern memory of the phone and the memory card you are using..
I hope this was a bit helpful.. Can you rate this solution please??
Dec 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Help increase msg memory of RAZR V3i
you can not store msg to your card nor can you increase the msg storage area for your phone.
Jun 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Can i increase the phone memory of my motorola v3? if yes, how?
regarding increasing phone memory:
Unfortunately, there's no way of increasing the memory space in a MotoRazr V3. I suggest you consider upgrading to MotoRazr V3i. It's got the same configuration as V3 but with the added benefit of expandable memory. With a memory card you can expand the memory upto 2 GB without affecting the speed of the mobile too much...
Mar 17, 2008 | Motorola Mobility RAZR V3
My important messages in v3i still remaining even i had swifted phone .
when you use a v3i the message memory in use was the phone memory..try changing the setting in the message set up to sim memory if it is available
Jan 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Memory problem
you will have to take the phone to a professional mobile tech and have them use special equipment to increase your phone memory.
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
