Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
How do change whirlpool duet dryer to a right side vent?
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$
Posted on Oct 01, 2010
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
We have a gas dryer whipool duet . It dry the towel but it still litle damp and the flame it good , no vent hook up , and it run for 70 minute cycle ,. Any idea why that happen . Please hepl
If you are not venting the moisture from the towels away from the rear of the dryer that could be causing your problem. If the dryer is up against the wall try either moving it away from the wall or hooking a vent hose to the discharge and at least pulling the other end of the host around to the side of the dryer. The dryer pulls air into it self from the rear and bottom of the dryer so it could be pulling the moisture from the towels right back into the dryer making it take longer to dry. Hope that helps
Aug 29, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet is not drying....it is not getting hot. It appears to be drying but it is not getting hot. I have to run the dryer multiple cycles.
Check for crimp in your vent line, Check your breaker. It is a dual breaker if one side pops it will run with no heat. Check those first.
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer vent
some have a knock out plate on the right or left side. then you buy a conversion kit, which is an elbow and couple of pieces of pipe.
Jun 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Want to vent the dryer out of the right side not the back.
take the back off. knock out the piece you want and move the exhaustr hose connector to the new hole
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer vent re-routing
Dear sbrown183,
Welcome to fixya,
You asked for the procedure to re-route the vent from the rear to the left side.
Here below are the instruction you requested for venting both the rear and or the sides.
If you follow these manufactures directions and you will be fine
You will find them on pages 11, 12 and 13.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208533582.pdf
Let me know how you do.
Please remember to leave a solved rating!
Thanks for using fixya
Huuum
Sep 04, 2008 | Whirlpool GEW9200L Electric Dryer
How to Side Vent a Duet GEW9250 dryer?
you dont need a kit, get under ther with an elbow and some solid vent tubes, a little foil tape and your in, should be a prefforated knock-out where it will vent through side,
Feb 12, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Jan 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Washing Machines Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
