Question about Sony CDX-GT520 FM / AM Receiver
No sub signal from a CDX GT520.
I just installed a Sony CDX-GT520 with a sub and amp in my 2007 Scion Tc. The install went fine except I get no sound from the sub. I configued the sub from the deck but I don't know what else to do. The amp is getting power and the sub is hooked up correctly but no sound. Any suggestions? Thanks.
  • 733 Answers
Connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Posted on Sep 07, 2009
Body control module 2007 scion tc
2007 Scion tC Body Control Module - 1A Auto
www.1aauto.com > 2007 Scion tC
Shop at 1A Auto for a brand new Body Control Module (BCM) replacement for your2007 Scion tC at a great price. 1A Auto has a large selection of Body Control ...
HELP!!! BCM issue 2005 tc - Scionlife.com
www.scionlife.com/forums/scion-tc.../help-bcm-issue-2005-tc-165745/
Jun 30, 2009 - i think i have a possible BCM (body control module) issue with my 05 tc, ... Using 2007 Air Box in a 2005 Scion TC, chowdahound, Scion tC 1G ...
2007 Scion Tc Body Control Module - Auto Parts Discounter
Dec 13, 2015 | Scion Cars & Trucks
Tip
Switch rear/sub
Hello guys, someone can help me ? i bought a sony cdx gt 520U , according to the manual there is a option in general settings were i can switch the SUB/REAR but i cant find it ...
i got few options in general settings like Clock,CAUT ALM,BEEP,AUTO OFF,CT,BTM,ZAPPIN
on Sep 26, 2013 | Sony CDX-GT520 FM / AM Receiver
I have a sony xplod cdx-gt520. I just put in new speakers, and the radio works fine but when I plug in ti aux I get no sound. The display shows there is musix playing but no sound...
double check that you have the cables plugged into the "AUX IN", and that the "AUX OUT" is going to the amp. or just not connected if you have no amp. If that is correct, then try a different AUX cable, you may have a broken ground in the one you have.
May 08, 2012 | Sony Car Audio & Video
Where does the remote wire for amp go to on sony xplod cdx gt520
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
Aug 01, 2011 | Sony CDX-GT520 FM / AM Receiver
Hi I have a 2007 scion tc. One of the lamps of my headlight (smaller brighter one) went out. I read somewhere that you have to remove the front bumper to replace it. Is this true or can i simply open...
if you still have the lights that came with the car, open hood and reach in, turn the lamp base counterclockwise and remove it, change lamp and install backwards
Jan 26, 2011 | 2007 Scion tC Coupe
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
We were driving my car down the road and it made a banging noise and just turned off...what could it be and is it expensive to fix? 2005 Scion TC
sounds like it needs a motor... check your oil and coolant... motor either ran out of oil or overheated either way the engine is probably smoked... most engine jobs run around 5000 dollars
Jul 16, 2009 | 2005 Scion tC
Sony CDX-GT520 FM / AM Receiver Logo
208 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
