HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP P/N: 5188-2625, Genuine Bestec 300W PS2 Replacement Power Supp...  Power Supply
Problem for HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP P/N: 5188-2625,...
Bad power supply?
By drsandine on Sep 07, 2009
Power supply green light is flashing. What does this mean? ATX-300-12Z Rev. BD
Best Solution
posted on Sep 07, 2009
Very Helpful)
palaboy
Rank: Wiz  HP Expert
Rating: 82%, 1198 votes
hi,
ATX-300-12Z Rev.BD is a 24 pin ATX with SATA
to initially check if it is good you can try these for a test:
1) disconnect the AC mains plug from the wall outlet
2) disconnect the 24 pins to the main board
3) try to have a small piece of wire short the green and black wire
through the hole on the connnectors
4) now try to just momentary plug the power supply to an outlet
i repeat momentary
5) if the fans of the power supply spins, it means your power
supply is initially good.
6) these part should be done with a lot of care measuring
output voltages.
7) try to wear rubber shoes and not to touch any metal connecting
to the unit.
8) there are a lot of other output voltages, initially that is only 12v
as it is the supply of the fan.
9) there are, 3.3V, 5V stndby, 5V running , there are also negative
voltages
10) to be very precise with the measurement digital tester is best
if you dont have these even the analog ones are good.
11) please dont try to measure voltages if you feel you cant measure
the output voltages have someone assist you and note down
the voltages you have taken.
12) please be careful when measuring output voltages
your reference is the black wire, should be connected
to the negative probe of the multimeter.
hope i have helped you, thanks for using Fixya!
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thanks for the test jumper info. My power supply was bad. " - drsandine
Solution #2
Helpful)
keiffertech
Rank: Wiz
Rating: 83%, 30 votes
Do yo have a volt meter or an atx psu tester?
you can check voltage to see
If a power supply is bad, your pc will turn off or/and turn on and turn off. As long as your system is running without and shut downs your good.
However if your pc is turing off, I would change it as soon as you can. basically what is happening, when you unplug everything there isn't much of a draw on power so the light remains steady, but when you plug devices in there is a draw and the PSU cannot deliver.
I hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks " - drsandine
Popular Solutions for HP ATX-300-12Z, ATX-300-12Z
Questions and Unsolved Problems for HP ATX-300-12Z, ATX-300-12Z
Do you recommend HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP P/N: 5188-2625, Genuine Bestec 300W PS2 Replacement Power Supp... (ATX30012ZREVCDR) Power Supply?
Answer
Answer
On T5048,photo thumbnails open very slowly and are only half-size
Answer
the image it is not working no power is not working
Answer
looking for specs for ibm 5150438 power supply in particular the input voltage and frequency
Answer
The LED on the power supplu is blinking green and the machine will not power up is this a power... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP ATX-300-12Z, ATX-300-12Z...:
Top System Power Supply Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more System Power Supply Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
