Question about Onkyo TX-SR705 Receiver
Trying to connect two outdoor speakers
After connecting the 2 speaker instllated outside the house by swiming pool to my sony receiver,,, there is no sound. any suggestion. i just want to connect the existing speaker to my receiver
  • 1 more comment
  • lahernan Sep 08, 2009
    We have tried connecting to both Zone A and Zone B and neither has worked correctly with the existing wiring by the home-builder.
    If we use our own cables (16g), for testing, the speakers work fine.
    We have tried with A, B, and AB and nothing seems to work.
    The house was pre-wired for surround sound in the family room, 2 outdoor speakers, and 2 speakers in the dining room. We have tried with all possible connections and nothing seems to produce sound with the existing wiring. We are only able to get sound with wires that we bought for testing.
    Also, we are not trying to connect the surround sound as we have an independant Bose 321GS.
    Any help is greatly appreciated.
  • cmcarlson21 May 11, 2010
    Are you trying to connect them to Zone 2?
    President:
  • 2,049 Answers
More than likely you connected it to the Speaker B terminals in the rear of your receiver. Look for a button or switch on the front and change to either Speaker B for outside only or A&B for indoors and outdoors.
Posted on Sep 07, 2009
Hi - I have a Sony V444ES receiver that I have four speakers on A (in house) and two on B (outside). I hooked up a third speaker (rock speaker) for outside use however the sound is very low compared to the...
What's a rock speaker? All you will hear with one speaker on the Rear Right output is the Rear Right channel which is typically for effects and ambience. You DO have a manual, right?
Individual speakers commonly have different responses given the same amplifier input. Where you physically place a speaker once it's electrically connected is up to you. Speakers placed outdoors might not have the sound-re-enforcement of nearby or adjacent walls as indoor speakers do so they will sound weaker.
Jul 11, 2011 | Sony STR-V444ES Receiver
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
How do I connect outside pool speakers to my Yamaha RX-V367 receiver. The inside surround sound is all hooked up and sounds great, but I can't figure out how to hook up the outside speakers separately from...
You have two speaker switch overs- A & B. if either one is not connected you can use this for the external speakerr connecting the right and left identically using good quality speaker wires. howeverr do not use more the 10 meters( recommended 5 meters). otherwise you will need to ahve an external switch( 2pole two way) for the surround speakers to switch over in place of the swimming pool, connected in the same polarity and phase.(Positve and negative). Ok
Jul 01, 2010 | Audio Players & Recorders
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
What is the correct speaker connection configuration for 5.1 surround and 4 outdoor speakers for stereo music?
Use a speaker switch box but amp may switch off at higher volumes.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | Audio Players & Recorders
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
Onkyo TX-SR705 Receiver Logo
303 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
