Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice tray dont empty and water keeps running out
Water
  • Whirlpool Master
  • 1,606 Answers
Something caught inside the water valve (replace water valve ) such as dirt , sand . Or , the icemaker died in the fill position . Disconnect the icemaker plug inside the freezer , and see if water still runs from the icemaker fill tube . Also make sure the icemaker fill cup on the icemaker , is not clogged with ice .
Posted on Sep 07, 2009
Too much water at refilling of trays causes an overflow and a big blob of ice which clogs the mechanism.What is my problem?
If the tray is not emptying completely, this would cause an overflow. If the tray is emptying ok, I would suspect the solenoid valve that opens to supply water to the ice maker.
Mar 02, 2015 | Refrigerators
Ice maker not working.
If your water tray was empty check the water supply to the fridge .
you shouldn't fill it manually.
\if the water supply is turned on, then the operating solenoid that allows water into the tray is faulty.
Whoever repaired your fridge should be called back immediately.
Dec 02, 2014 | Refrigerators
No sign of ice maker making ice
The water valve could be bad or the icemaker may be bad.
Oct 11, 2014 | Refrigerators
Water keeps running
where is the water running on the ice head or is this a remote water cooled condenser? If water is running all the time at the ice head into the sump tray and overflowing into the ice bin then check the water inlet valve ether rebuild or replace valve but make sure the water low sensor is not calling for water when the sump tray is full of water.
Jan 12, 2014 | Scotsman Cooled Modular Contour Cuber...
Ice maker runs continuosly but no water is in the cube tray
It could be the valve. If it does not let water in, it will try to make ice and none forms so the motor keeps turning waiting for ice to form.
If the motor is turning its fine. Concentrate on how the water reaches the tray, its probably not getting there.
Dec 22, 2013 | Whirlpool Refrigerators
The tray under the freezer has filled with water and is leaking all over my floor. How do I empty the tray and why is this happening?
the tray is large enough for a normal defrost. if over fowing use a turkey baster to remove water . then ck to see why the water is not evaping . the fan in back may not be going . ( mouse in fan (commn ) if fan is ok just remove water and keep your eye on it . normal defrost is about 1 cup water every 8 hr's or run time . / pan hold about 4 cups .or more. water valve in back may be leaking into pan ( turn off water till valve is replaced . **** .
Dec 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker dont work
If tray is empty lets fill with water from tap and wait to see if it freezes and dumps. If yes and don't refill then I need the model number so I can help you better. It may need a water control valve or a thermostat, Thanks, Se Breeze
Jun 18, 2009 | Montgomery Ward Refrigerators
Ice maker continualy runs even when ice tray is full
theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
Jan 10, 2009 | KitchenAid Architect KBRA20EMSS Bottom...
Ice not dropping
Press the little button on the bottom right of the ice maker and clear the tray of ice. The maker has to be turned on for the tray to tilt and empty. This corrected the problem for me. The freezer side may have been left open and and the ice maker filled the tray while the door was open, I suspect.
Nov 12, 2008 | LG LRSC26940ST 36" Side-by-Side...
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
218 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
