Question about Kenmore Refrigerators
My ice maker freezes solid.... - Kenmore Refrigerators
  • Kenmore Master
  • 8,220 Answers
Posted on Sep 07, 2009
  • 159 Answers
SOURCE: no water pressure for ice maker or water despenser
Sounds to me that you attached a bulet piercing valve to a cold water pipe. If you did I would say the tiny hole that the valve put into the pipe has blocked up and causing your low water pressure. I have sen this problem a million times with that type of valve. You could try to close the valve and then open it back up. Sometimes this will clear the hole. If not I would replace the valve with the type of valve you have for your sink. there better in every way. You may need to have a plumber do the job for you but you will never have this problem again. Good luck
Posted on Jul 12, 2007
kweaver1
  • 3 Answers
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Posted on Jan 20, 2008
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
  • 286 Answers
SOURCE: WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
Posted on Jul 01, 2009
  • 3 Answers
SOURCE: ICE MAKER NOT WORKING PROPERLY. ICE WILL FREEZE
if water is running in, your tubes are not frozen. More than likely it is the arms that eject the ice are not working and turning to move them out. Check that. Ours were moving some, but not all the way around. We called someone out and they said it would be $500 to fix. We ordered the part online after calling the company and getting the part number, it was a $110, looked up the manual online, it took 3 screws removed and 1 connection and me and my mom replaced it. Not as hard as the tell you, just get online and find the manual that tells you how. I promise not hard, we were very proud of ourselves!!
Posted on Jul 14, 2009
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
What causes ice in ice container to freeze into a solid block?
The water control valve has trash in it or is otherwise malfunctioning and isn't shutting off water completely when filling the ice maker. Water then leaks over into ice bucket and freezes solid.
Sep 01, 2014 | Frigidaire Refrigerators
After harvestering it take 10 mins. to kick back into freeze again
Replace the ice thickness control hanging on front of the evaporator plate
Dec 06, 2013 | Scotsman Cooled Modular Contour Cuber...
Model TSS42QB. The tube to the ice maker freezes
replace the tube / the new style tube will have the top missing .they cut it out . this lets air in and no more ice build up ..mm
Jan 18, 2010 | Refrigerators
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Jun 18, 2009 | U-Line BI-95
Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
Sep 04, 2008 | Whirlpool GD5SHAX Side by Side...
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
