Question about Poulan WeedEater Hedge Trimmer 25cc Engine
I have a TROY-BILT Backpack Blower, 25cc. runs and starts ok, but when i push the throtle to go faster the motor will stop running thank youy bill
  • lucky99star May 11, 2010
    will it run if you leave the choke on partially? if so you need to have it serviced including a carb adjustment or rebuild if unadjustable
  • 43 Answers
The choke might be back wards
Posted on Sep 07, 2009
TB BLOWER 25CC WHATS THE OIL/FUEL RATIO MIX???
Try 40:1. Better to have too much oil than too little. If you find the exact ratio then use that. ...Lee
Mar 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
RUNS SLOW AND THEN STOPS LET IT COOL AND IT WILL RUN AGAIN
I had the same problem witha similar 2 stroke blower
& it turned out to be caused by a blocked up exhaust port.
Remove the muffler & check both the port & the muffler for carbon blockages.
Before you re-fit the muffler use a torch & look up the exhaust port to see if the piston & rings look ok(not scored)
Hope this helps
regards Andrew Porrelli
Dec 07, 2009 | Troy-Bilt 25cc 2-Cycle Backpack Blower...
25cc TB25BP new plug, new Gas, Clean Carb.. will not start
Check Make sure its the right plug.- Check for stuck choke-Check.Air/fuel mixture screws out of adjustment.
Sep 22, 2009 | Troy-Bilt 25cc 2-Cycle Backpack Blower...
Replacement suspension for the troy-bilt back pack leaf blower
http://www.troybilt.com/webapp/wcs/stores/servlet/topcategory_10001_14102_-1
Jul 30, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
What is the mix ratio for the troybilt 25cc blower?
Troy-Bilt products now are usually produced by Mtd, the ratio being 40:1.
However since John Deere made yours I'm 99.9% sure it should by 32:1.
In any case any power equipment you own (including Dolmar or Stihl) that takes an oill/gas mix benefits in the long run from using the richer 32:1 ratio. It protects the piston and cylinder much better, giving your equipment longer life. Do not use the "one mix for all" that you find at retail stores as it has been my experience it really isn't "one mix for all". Seen a lot of scratched pistons and broken rings from people using that.
Jun 17, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
240 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
