Question about Refrigerators
GE side-by-side fridge is warm at the top of the freezer and fridge but freezing at the bottom of both, any ideas?
  • 3 more comments
  • roy_musa Sep 10, 2009
    I'm not 100% sure but I do believe it's one compressor. Is it possible to be short after 3 years of usage?
  • roy_musa Sep 18, 2009
    Yes one compressor for both fridge and freezer.
    Model # GSS25XGPD
    Side-by-side freezer and fridge
  • thabiet971 May 11, 2010
    looks like you have a shortage of gas. do you have one compressor for both fridge and freezer
  • Controlfrk
    Controlfrk May 11, 2010
    Model number is needed to help. Problems such as this are usually caused by the fan in the freezer compartment not running. It is behind the rear wall. The fan motor may be bad or the door switch that operates it may be defective.
  • Refrigerators Master
  • 1,606 Answers
Either the fan in the freezer is not working , or you have a defrost problem ( frost on coils & rear inside freezer wall ) .
Posted on Sep 07, 2009
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Hi our ge refrigerator has freezer on top its freezing but not keeping foods cold in fridge.fridge is warm and theres two holes in fridge on top that keep freezing up.what should we do?
by the number on the refrigerator its a side by side,if the freezer is actually on top,then remove rear cover inside the freezer and the drain hole in the freezers plugged with mold take a wire and rat out this hole to get water to flow down the hole again
Aug 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
