o-rings would cause the gun/marker to have a lower pressure, due to leaking air/co2 their for their would be no way for it to shoot up to 500fps. I suggest trying a different chrono, might be defective. Also i recommend an after market power tube. I recomend buying the Red Hot Power Tube from JSC its slightly louder but lets you get more shot out of your HPA or CO2 as well as makes chronoing a heck of a lot easier.
Hot Tub, 2003 master spa model 557-while on the normal circulation cycle the pump stops for about 5...
(More)
Hot Tub, 2003 master spa model 557-while on the normal circulation cycle the pump stops for about 5 seconds then starts again, this happens about every 5-10 minutes
A-5 is leaking/blowing nitro out near the tombstone. I took the A-5 apart to inspect o-rings. Did...
(More)
A-5 is leaking/blowing nitro out near the tombstone. I took the A-5 apart to inspect o-rings. Did not find anything wrong with them. Whats next?
