Question about Adobe Photoshop 7.0 for PC
Adobe photoshop 7 either stops working and closes or causes my computer to freeze up completly
  • 30 Answers
There are many reasons why a computer may freeze or completely crash. The most common reason is an overload in the memory. Computers have a set amount of memory to work with (this is their RAM, or "Random Access Memory"). If you attempt to do more with the computer than it's capable of handling at one time, it may "crash" in an attempt to save itself. Generally, the cause of this is generally that too many programs are running at once for the computer to handle. If you are not using a program, close it. Conflicts between programs are other well-known reasons for crashes. Programs such as virus detectors are notorious for conflicting with other applications and utilities. If you notice that crashes are occurring while the same two programs are running, try to avoid running these two programs at the same time.
What Can I Do?
  1. Take Notes
    Your first step should be to pay attention to what was happening at the time of the freeze or crash. Try to isolate the program that may be causing problems (this can help prevent a further, more damaging, crash). Is there a history of problems with a particular program (or combination of programs) on your computer? Were too many programs running at once? Was it a particular task you were trying to do? See if you can form a hypothesis about the cause. By understanding what may have caused it this time, you can attempt to avoid future, similar occurrences.
  2. Try to End the Program
    Windows provides a "Task Manager" that lists all current programs in operation. In Windows 9x & ME, this menu is brought up by pressing Ctrl + Alt + Delete at the same time. In Windows 2000, after pressing Ctrl + Alt + Delete, click the "Task List" button. In this menu, you can attempt to individually close programs that are causing problems. If programs are unresponsive, Windows will attempt to notify you of this in the Task Manager.
    If you are able to effectively close the program causing problems, save your work in all other open programs, and reboot your computer. This will help to prevent further crashes, and give your system a clean slate to work from again.
  3. Reboot
    If you are not able to effectively close the program in question, you have several options. Please note that any changes in unsaved documents WILL be lost in a system reboot. With the Task Manager open, try pressing Ctrl + Alt + Delete once more. Windows will attempt to reboot itself.
    If the Task Manager does not respond, you still have a few options. Check your computer's tower to see if there is a "Reset" button (it will be in the general area of the normal "Power" button, and should be slightly smaller than it). Press the "Reset" button, and your computer should reboot.
    If you are unable to find the "Reset" button or do not have one, there is one final option to pursue. Find the "Power" button on your computer's tower. Press and hold this button. You will need to hold it for a few seconds (sometimes up to ten full seconds). At some point, your computer should shut down completely. If nothing happens, keep holding the button. Do not press and let go without giving the computer a fair chance to shut down.
Posted on Sep 07, 2009
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Jul 02, 2011 | Adobe Photoshop 7.0 for PC
Photoshop cs3 is freezing my system as this problem occurs on our different specifications systems
The most common cause of computer freezes is a corrupt registry.
Most likely your registry is bloated and overstuffed with an assortment of useless pieces of data. The operating system while running your computer has to pick its way through all this excess material. There will be bits of programs which were not completely uninstalled, parts of programs which were never completely installed, fragments of miscellaneous data, useless drivers, and a multitude of other bits and pieces.
The answer is to clean your registry and remove all the material which is not needed.
http://fix-pc-freezing.com/Clean_Up_Cent…
Get the best one, and completely clean your windows registry with a few clicks of the mouse.
Often there is also spyware which is using your computer for nefarious purposes and slowing its operation.
The answer is to scan your pc with a best anti-spyware to clean spyware/trojan/virus.
http://fix-pc-freezing.com/comparison.ht…
Feb 12, 2010 | Adobe Computers & Internet
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
Aug 10, 2009 | Adobe Photoshop Elements 2.0
Serial number for photoshop elements 7
Try calling the company and tell them you bought the program and the serial no. doesn't work. If that doesn't work do a your favorite search engine serial for photoshop elements 7. Warning, do this can cause harm to your computer, with adware, mailware.
Aug 09, 2009 | Adobe Photoshop 7.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Editor not working
OK U SHOULD CONTACT THE PRODUCT DEALER BUT ONCE U CHECK THE SYSTEM REQUREMENTS AND CHECK ALL THE COMPONETS ARE THEIR OR NOT IF ANY ONE IS NOT THEIR U SHOULD INSTALL AND IT WILL WORK AND ONE MORE U SHOULD DOWNLOAD THE ADOBE PHOTOSHOP UPDATES U CAN DOWNLOAD FROM HERE ok rate me please 100%
May 25, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 6.0 (editor) stopped working...
It's most likely incompatible with your system. That's a very old version of Photoshop.
May 10, 2009 | Adobe Photoshop 6.0 for PC
I can't open my adobe photoshop 7
This type of problem can clear by "Right Click" on Photoshop 7 Icon and click on "Run" option then "uncheck" the Protect my computer... then click ok..
or
create a new account on Windows and try in new user 100% working
Mar 17, 2009 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 for PC Logo
212 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
