Question about Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dvd rom problem
Dvd rom loads cd but will not follow through with playing the disc.
  • 30 Answers
Try to turn off the vista's burning feature.
It's not yours or anyones burners....just an update in vista which buggered the policies up
Go to your run command and type (start.....Run.....)
type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1.
This should fix the problem
Posted on Sep 07, 2009
What video formats will RCA DRC279 DVD Player read
Hello
This player is compactable with DVDs, ACDs, Video CDS, CDs and JPEG files. You can't play the following type of discs. Laser discs, CD-1, CD-ROM, DVD-ROM, or discs recorded using other boradcast standards (ie PAL or SECAM); CDG discs.
If you want the user manual to this player, inform me by fixya comment, along with your email address. I'll send a copy of the user manual to you by return mail. It has all details. I can't send it to you by this window, as it does not allow ma to upload PDF files by it.
http://www.dataentryjobs.us/67948.html
Feb 27, 2012 | RCA DRC279 DVD Player
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
DISC NOT LOADING
there are 2 reasons, your cd rom lens might be dirty and needs to be cleaned, you may use the lens cleaner cd. and your cd you are loading might not be supported by your cd rom, a different code could also one reason.
Jan 31, 2008 | Toshiba SD4990 DVD Player
Playing dvd's
Inside the Control Panels, look for System. Double-click System and choose Device Manager. Inside Device Manager, find the CD/DVD and "Uninstall" the device. Restart the computer and let it re-load the driver. This might help. You can also try a CD/DVD laser lens cleaner.
Nov 12, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
Dell (313-1220) CD-RW/DVD-ROM Combo Drive Logo
123 people viewed this question
Alun Cox
