Question about Averatec 3200 Notebook
Looking for a circuit 0442k rev#d The plug that you put into computer from the wall electric outlet The plug inside the computer is broken
  • 855 Answers
Try action-electronics.com or cablewholesale.com I think you will have better luck with action-electronics.
Posted on Sep 07, 2009
  • 30 Answers
You might find it here
circuit
detective.com/
I just bought a 1997 Fleetwood prowler and only have electric to the front half of the recipt plugs nothing in the galley or above the table what can cause this
Several things.
I hope you will be able to locate the fault.
Start with a bad circuit breaker.
Once in a while, a circuit breaker will be good-looking, but be no good.
Test that with a electric meter at the side where the wire attaches under a screw.
If all circuits are HOT at the circuit breaker box, suspect a burnt or broken wire somewhere between the box and the "dead" area.
Know that traditionally, the outlets and lights are not in parallel, they are often in series.
That means, an outlet can have a broken or fried connector tab between one plug and another, which can can use the whole system to be dead.
Look at a duplex outlet that is "loose". ( Hold it in your hand)
See the 2 tabs on the sides that connect the top and bottom outlets. If a tab is missing, one plug will be hot, the other dead. If wires go from the dead bottom one to other outlets or lights, they will all be dead also.
God bless your efforts.
Nov 10, 2015 | Cars & Trucks
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I have an HP Pavillion 630 computer that will not start. The led light on the back does not light up on the power supply when plugged. The power supply number is hp-d3057f3r. Do I need to replace the...
Check your outlets first. If using a uniterruptable power supply (ups) check circuit breaker on the UPS. If no worky, unplug the computer, then plug in a lamp or something that you can identify as truly ON.
Assuming it lights up, plug the computer directly to the working wall outlet. If the wall outlet doesn't work, go find the circuit breaker box, and reset as needed.
If wall/power strip/UPS, circuit breakers are in/closed and all work and the computer still won't power up. You most likely need to replace the power supply. Pretty straight forward. Unplug from electricity source. Ground yourself before you start jackin' around inside. Then look at the plugs going to the motherboard and drives, note orientation, color and pin placement. Yank it, toss it, replace with new http://r.ebay.com/BYvShq.
Jan 29, 2018 | Hi-Pro (HPP303W) 300-Watt Power Supply
Grill problems
I would advise not to use the grill or the plug it plugs into before determining what the problem is. It could be the grill cord, or the wall plug.
If you have been in the habit of pulling the cord plug out of the wall by tugging on the cord, then chances are the problem is broken conductors inside of the wire insulation. One way to test this is to attempt plugging the unit into a totally different wall outlet. If the cord and outlet heat up again, chances are the cord needs to be replaced (if possible). If the both do not heat up, then the outlet wiring connections inside of the wall need to be checked.
Bad wiring connections either in the wall, or in the cord, will generate heat, when will then conduct to the other connector. So it is difficult to use heat as the indicator of which connector is bad.
Dec 10, 2009 | George Foreman GR36P
I would like to put a danby on an electrical timer so I can dehumidify my camp trailer 2hrs a day. It has a soft start though. Is there a way to do it?
If it plugs into a wall outlet of 120 volts then all you have to do is go to a hardware store and buy a timer that you plug into a wall outlet and program it for two hours a day and then plug the danby into the timer. But make sure the timer will carry the amp load of the danby, for instance wall outlets are usually 15 amp, so the danby amp rating should be 10 amp or less and you don't want anything else on that circuit.
Nov 24, 2009 | Heating & Cooling
Dryer wallplug heats up
you may have aluminum wiring going from your fuse box to the wall plug (older house) .. if this is the case then you have to have a special wall plug that is approved for aluminum .. if you use a standard wall plug then you will get what you are seeing (it gets hot after a few years) .. the connections work loose and start to get hot .. if you have copper wire then you might also have either loose connections or the springs that make contact to the plug have lost tension .. make sure you turn off the circuit breaker before doing anything inside the wall plug box .. make sure water hasnt damaged things inside the box .. once the box has gotten hot the integrity of the spring contacts cant be trusted .. (they lose their spring force when they get hot) .. so no matter what kind of wiring you have you should replace the wall outlet .. if you have aluminum wire (white looking) then get an outlet that is aluminum certified .. if you have copper wire (orange color) then replace the outlet with one that has a rating of 20 amps .. that should fix your problem.
Oct 23, 2009 | Speed Queen AGS28AWF Gas Dryer
I need a power source adapter for my Nortech
I have a similar unit with tandem DVD's.
Chances are that your power source is good and the problem is the power port on the side of the unit. Both of my units have a broken post on the back of the circuit board. I've tried to solder them with limited success. One lasted two weeks, the other has brought me to this site looking for a service center. I'm sure it's a poor manufacturer design that puts too much stress on the solder post.
Jul 01, 2009 | Televison & Video
The speakers do not sound good,
I bought cheapy speakers for my computer and they sound amazing ... like $20 at Target. :)
However, if you are looking for decent sound, here is a review of some top speakers.
Mine came with detailed instructions in the box, which amounted to - plug into the electric outlet on the wall, and then put the green plug into the green dot on the back of my computer. Super easy!
Jun 14, 2009 | Dell A215 Computer Speakers
No Power with dryer plug in
Plug light or something into wall outlet to see if you are getting power.
Got power then check for power at power cord inside machine.
Check power at timer.
If there is power at timer then circuit testing come into play.
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Lights & outlets in addition, how many on 20 amp breaker?
I would say something a little different than SmithBrother. You said you are putting on an addition and you asked how many outlets can you put on a 20 amp breaker. Because of the date on your comment, it is probably a little late to be replying but whaat the heck ... here goes.
I think there is a rule of thumb that you can put about 12 "holes" in a 15 or 20 amp circuit. A "hole" is a hole in the wall where a box would be put for a outlet or a light or a switch. I presume you know to use #12 wire on a 20 amp circuit and while you may use #14 on a 15 amp circuit, I prefer to shy away from #14 wire even though I MAY protect a given circuit with a 15 amp breaker. You can over protect but not under protect. 30 amp is #10 and so forth.
There are lots of other considerations ... too many to do justice in this short comment. However, I will hit a few hi lites. As SmithBrother says, a micro wave should have its own circuit as should a AC or a frig - I think that may go without sayng. I think you are speaking more general use. I believe the electric code says every wall must have a plug in it and you can go no more than 6 feet to get to a plug. So, if you have a 12 foot wall, one outlet in the middle will meet the requirement. There is nothting preventing you from puttine two outlets in that same wall. From my perspective, I want to have lots of outlets and I want them to be convenient for me to use. (There are more than 200 outlets in my home) Another thing, you cant put a outlete over a electric baseboard heater. You can put one at each end of such a heater but not where a lamp cord would lay in top of the hot heater surface.
Regarding the 12 hole rule ... if you have two switches that control the same light, you only count those two switches as one hole even though, obviously, there are two holes in the wall for the two switches. Count a second hole for the light. Conversely, if there is a light and a fan, you should count that one hole in the ceiling as two.
Mar 11, 2009 | Electrical Supplies
Averatec 3200 Notebook Logo
49 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
