Question about Viking VGSC366-6B Gas Kitchen Range
Viking Range I have a six year old VGIC306-4B - 30" wide range with four burners, single oven. When using the oven, it takes a very long time to pre-heat, sometimes as long as an hour. I can see that the gas flame is weaker on the left and I can see that the flame fluctuates in size as it is heating up. All the burners and the broiler seem to work fine. Is this a regulator problem? If so, is there a regulator that I can replace or clean?
  • 1 more comment
  • wrinkledman Dec 29, 2007
    This looks like a possible solution, but 125.00 (for two Maytag components) is a lot to spend on a guess. Have you done any more research?
  • wrinkledman Mar 16, 2008
    http://www.repairclinic.com/SmartSearch/...
    This link is exactly right. I bought these parts for under 40.00, including shipping for both on ebay and installed them in less than an hour with no special tools. It took a little bit of work to get the old ones out, but not too much. I didn't have to break or force anything. My oven works better than it did when it was new. No exaggeration.
  • heatheoven Jan 10, 2009
    I have a Viking Range Model VGRC365-4GD which is taking up to an hour to get to 350 degrees; I took the bottom liner out, turned on the oven and noted that the left ignitor did not light up at all - so all the work was being done on the right side. Is the only part needed a new ignitor? and do I understand that Maytag makes a comparable & better part than Viking?
    Thanks.
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Posted on Dec 26, 2007
  • 906miles Mar 18, 2008
    Sounds identical to my symtoms (make that my Viking's symtoms). The Maytag part works fine. Fit is exact and the mounting plate is identical. You will need to wire nut the connections Vs a spade type connector on the original, but other than that it should solve that problem.
    I don't know the technical relationship with ignitors and the valve/regulator, but there is. I believe that when the ignitors are not drawing enough amps the regulator/valve senses that condition and reduces gas flow. Most likely a safety feature.
I don't have the answer down pat. I'm a DIY with a similar experience. I had my ignitors replaced about three years ago (Viking parts) and they are suspect again! IMO, very short life span. The Viking parts are more expensive. The link mirrors my experience and when I replace mine again I'll try the Maytag part and repart back on the fit/function. A little shopping around gets the part at ~$40 ea.
Posted on Dec 30, 2007
The ignition of the oven is erratic. Some times it won't ignite. sometimes it dosen't ever reach temperature. sometimes it work as expected. Sometimes it will ignate if one of the(stove top) burners is...
NO LONGER NEED ASSISTANCE. FURTHER RESEARCH ON THE INTERNET DISCOVERED OTHER STOVE OWNERS WITH THE SAME PROBLEM. IGNITOR REPLACEMENT FIXED THEIR PROBLEM. I'VE ORDERED THE PARTS.
Jan 23, 2010 | Viking VGIC305-4B Gas Kitchen Range
Oven in my viking range takes over 1 hour to heat to 350 degrees after another hour it is up to 385. degrees This is an ongoing problem the range is about 10 years old
Sounds like your ceramic ignitors have worn out - apparently they are to be replaced every 3-5 years - so if you've gone 10 this could be your issue (it was mine). I have two in the larger oven & 1in the smaller one. Easy to replace (60$/each) - two wire and one screw each. When they fail to heat up properly the gas valve doesn't open fully, or won't open at all.
Also I'd clean the burners when in there ... mine corroded a bit and required brass wire brushing. There is a small **** on the burner that had filled in (width of a piece of paper) which prevented the flame from moving to the opposite side of the burner - so essentially only one side of the burner lit.
Nov 26, 2009 | Viking Professional Premiere VEDO527 ...
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Single element in 3-way burner won't work
Hey Janice,
Sorry to hear this.. but, here is a site that will answer your question more completely.. ( I think this is a complete replacement job).. and if your are mechanically inclined, you might be able to do it yourself... good luck,,
as far as costs... that's such a wide range of "prices per hour or by the job", it would not be feasible to put a $$$ figure on here..
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/94552-glass-surface-triple-element-replacement.html
Jun 19, 2017 | Maytag MES5775BAF / MES5775BAN /...
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
30 inch Viking ultraline stove, 6 years old. You have 2? burners on the bottom in the oven. One on the right "buffs" or seems to go out then reignites. The "cook" also says it takes...
We inherited a 30 inch Viking Ultraline when we purchased our current house. I was extremely excited to cook on such a high-end range, but this thing has been nothing but trouble. The temperature on the oven is always between 25-75 degrees hotter than indicated on the dial. An oven thermometer is the way I solved that problem. None of the igniters work on the burners (I use a BBQ lighter on all the burners) the broiler has never worked, and one of the hinges broke and required replacement. We actually ordered the hinges off the internet for $25 each and replaced them ourselves--it was not complicated but would have been costly to get a tech out to do it.
After repairing the hinges, I decided to use the self-clean function, which, big surprise, not only did not work, but locked me out of the oven! I tried re-starting the self-clean, breaking the circuit and re-starting it and nothing worked. Having read many posts on the internet, I realized I would probably have to get a tech in to fix it for me. In desperation, I finally turned the oven on to 325 for 20 minutes, hoping it would unlock, and inexplicably, an hour after I turned it off, it unlocked itself. Finally, the burners are impossible to keep clean--no matter what I do to clean them, they always look filthy.
I would never buy another Viking product, as I am totally underwhelmed by the performance of this range.
Apr 21, 2008 | Viking Kitchen Ranges
GE gas stove XL44
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
Sep 21, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Viking VGSC366-6B Gas Kitchen Range Logo
1,085 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
