Question about RTO Outboard Motor Bass Fishing Boat Rod Reel Oil & Grease
Help. recently cavitated my 140 hp 1989 mercury outboard motor at high speed.I Removed the lower unit several times but only goes in forward about 5mph. Please help Tx jack
You may have spun the hub inside your propeller. Look between the center hub with the splines and the casting of the prop there is a rubber insert in there. See if it is distorted. The nut and washer are keeping the prop on but I think you will find if you put it in gear and try to turn the prop by hand it will spin and the shaft will not move.
Posted on Sep 19, 2009
  • 677 Answers
Not really sure what is wrong.Do all the gears work?Does the motor rev properly.Did you change the height of the motor.If the motor etc. are all ok and the motor cavitated at high speed,you may have spun the bush in the propeller hub.The symtoms are,everything works ok but the boat can rev but will have very little forward propulsion.If this is it,the prop needs to come off and taken to be rebushed.The bush stops major damage to the g/box if the prop strikes something.Hope this helps
Posted on Sep 07, 2009
  • 4 Answers
CHECK YOU HAVE NOT SPUN YOU DRIVESHAFT SPLINE IN YOUR CRANK
Posted on Dec 16, 2009
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
Suzuki outboard 8hp 1994, at higher speeds under loading prop appeared to cavitae, liek spun prop. repalced with new prop. On the bench, plugs removed, in forward gear hand turn prop thur haft turn and...
You may not be deep enough in the water and it really is cavitation.
May want to check the lower oil for metal as a Mostly worn out gear can do that
It's normal for a gearbox in forward to "click" in one direction and be firm against the motor when turning against the gears normal rotation.
Oct 10, 2012 | Light Boating
Water pump impeller change
There is another bolt up under the zinc plate on the cavitation plate.
Jun 04, 2010 | RTO Oar Sockets
What oil do i use in the lower unit of a 1989 90 hp mercury outbord
go to a marine store and get lower unit gear lube. it comes in a squeeze tune and just remove the plug and squirt it in . both screws need to be out tho upper one lets air out as you push new in lower .the put upper back in first keeping oil in till you put in lower plug
May 01, 2010 | Light Outboard Motor Boat Bass Fishing...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Jul 23, 2009 | 2004 Mercury Mariner
RTO Outboard Motor Bass Fishing Boat Rod Reel Oil & Grease Logo
403 people viewed this question
Top RTO Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a RTO Fishing Expert? Answer questions, earn points and help others
