Question about HP LaserJet 1020 Printer
Red light when printing
Sending document to print, printer responds as if it starts printing but then red light on & stop, no printing at all.
  • 30 Answers
It sounds like your problem is actually in your PC or Computer System. Possibly in your computers software, or in the internal settings inside your computer. I only work on the printers and you may need a computer trained technician. As this is a PRINTER REPAIR SITE, you may not find the help you really need. I do hope that someone that reads your message, knows about computer settings and problems and can help you further. If not, you might want to search for a computer repair site, for possible help...Just in case you want to be sure its not your printer, you can run a STAND ALONE PRINTER TEST, with your printer not connected to your PC or Computer System. Unhook the "printer cable" from the back of the printer. The power cord would still be plugged in to the wall and paper would be loaded normally. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or INFORMATION that may still have been in the printers system, from when the PC was previously connected. Now reach over and turn the printer on as normal. The printer should come on and go to a normal READY CONDITION, with no ERROR LIGHTS on. If you get an ERROR LIGHT on, then you know you have a problem in your printer. If there are no ERROR LIGHTS on, then reach over and turn the printer off again. You will now have to refer to your USERS MANUAL/OWNERS MANUAL for available "Internal EpsonSelf-Tests" that can be ran on your model of printer. Normally, you would hold-in on the button that is listed in your USERS MANUAL/OWNERS MANUAL and then reach over and turn the power button on, as you normally would. The printer will normally print out an "Internal Epson Self-Test Copy" and the self-test copy should be correctly fed thru the printer...AS A GENERAL RULE: If the self-test page prints out correctly, then usually your printer is working normally. This does not mean your printer may not be dirty, or have another service related problem, or even a bad ribbon cartridge. It just means the printer is basically working normally as far as the internal tests go. You could run this self-test several times [just be sure], but usually if it works once it will do the same again. If your printer is working ok, then your problem could be in your PC. Again I'm sorry, but as I don't work on PC's, so I can't help you with those type of problems. You may need to get help from a Computer Technician, if you do determine that your possible problem may be in your PC or System...If the internal self-test does not print out normally, then you can assume the problem is in your printer. If the test fails, then it normally would indicate a possible problem in your printers "main board assembly" [PCB], "printhead assembly", or a related electrical hardware type problem...Good Luck!
Posted on Sep 07, 2009
  • 205 Answers
May be tonner is empty.
Remove and reconnect power to your printer. Press and hold the on/off button for 3 seconds (sometimes 10 sec) and it will print a test page. If printing contains lining then tonner is empty. If sucessful then try to reinstall driver for this printer. Restart your computer and go to your Computer bios and set parallel port to ECP+EPP or Auto mode.
May be the above suggestions will help you.
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Hp laser 1010 printer not starting , red light blinks,
If red light is blinking, means there is pending printing document not yet printed. Just lift the cartridge door and close it back. if still not working. Just tell me what your do before and I will help your. Here is my email. Just send me email so we can troubleshooting together. I know this printer for long time.
Dec 30, 2010 | HP Office Equipment & Supplies
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
Jun 19, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Two red lights below buttons are continuously blinking & printer does not printing document
Hi I mhel I have a solution for your problem, you just have to download a program called SSC SERVICE UTILITY and install it in your computer. this is a free software . Just email me if this works and solve your problem
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
May 31, 2009 | HP Office Equipment & Supplies
CLP-300 Printer will not print!
Check for fragments of paper inside the printer around the rollers. If you find any, remove them. Turn off the printer and then turn it back on to see if it solves the problem.
Feb 23, 2009 | Samsung CLP 300 Laser Printer
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
No longer able to print
Look and see how many pages it's printed out if possible, You may need a maintenance kit with fuser. Also the age of the computer affects parts.
Jun 10, 2008 | Kyocera FS-920 Laser Printer
HP LaserJet 1020 Printer Logo
253 people viewed this question
Seeker5211
Seeker5211
