Question about Galaxy Radios DX-959 40-Channels Base CB Radio
I have galaxy dx 959 the freak meter shows 27.175 until you key down then it show 27.185 what do i need to do to fix ?
  • Steve May 11, 2010
    I don't have this radio but remember some things that used to be done to CBs in general. You might try / look at the items below. If this radio was "peaked" - did you have the clarifier modified? Try adjusting the clarifier while xmitting to see if the output display changes. Try on different modes and channels, too. A severely mismatched antenna system could cause all kinds of unexpected operation by reflecting RF current back to the xmitter. You might have some luck connecting the radio to a friends antenna system to see if the problem goes away. I hope this helps & good luck!
    Problem Solver:
  • 8 Answers
It sounds like the pc board is not grounded to the frame. remove covers wedge a small screw driver on the edge of the board against the frame housing with mic keyed up. caution not to much pressure don't break the board. check the black wire on the inside of the power cord plug. last try extra ground wire for power supply to a screw on the out side of the radio cover
Posted on Dec 13, 2009
Can you just show me how to key up my modulation on my cb radio galaxy 959 just the regular key up modulation thank you
vr16 .talk to someone and turn it all the way to the left then all the way right and have them tell you which has the better modulation.
Oct 09, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Why does the sound come back on when I press the mic on my galaxy 959
bad ground to antenna Check your SWR with a voltmeter and a swr meter.check everything, check your mic connection for broken wires try another mic.
Aug 01, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
959 With not work
check the board maby you have cut or short somthing
bernard
http://www.rylwy.com/
Aug 08, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
I overdrove my finals on the galaxy dx 959 by adjusting vr17 too far, now nobody can hear me
you probably blew your audio ic not you final .take it to a tech and let him fix it.
Jun 30, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 959 meter light does not light...is there a fuse for this?
No its a bulb and the radio has to have the face pulled down to reach the 4 screws to replace it.
Jan 17, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
When I turn the dx 959 and power back up again, the frequency meter shows 10.695 or 00.000. Sometimes, a slap to the box willcorrect this, but sometimes not. The radio neither receives or transmits while...
Hi, my name is John. Welcome to FixYa.Take the cover off, power it back-up, then with a pencil eraser end, mash around on the circuit board, looking for cold solder joints and re-solder them with soldering iron. This should solve the problem for you. Thanks for choosing FixYa....John
Oct 30, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Hi, does anyone know how to connect an LED to replace the original meter lamp on a Galaxy DX 959?, or please refer me to a site where to find this information. Thank you so much. Osvaldo
LED are diodes that operate around 2volts DC. A resistor must be soldered in series with anode or cathod side of diode if connecting to 12 volts DC. Anode to ground....if unsure start with 10k resistor and check voltage and work your way down to around 1.8 volts is ideal
Jan 24, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
144 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
